Need To Replace Some Trim Around Exterior Door - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-05-2011, 03:16 PM   #1
They're all fixer-uppers
J187's Avatar
Rewards Points: 516
Need to replace some trim around exterior door
It's masonite and rotting. I'm not sure what to replace it with. Currently it appears to be two pieces of wood, one is 1"x1" the other is 1"x1 1/4" stacked side by side, running from top to bottom. The closest thing I can find at my local big box is 1x1 trim that I can stack side by side but it's $2.01 per linear foot!! Which means around $60 for this little piece, since it's over 80" and I'll need two for each side. What is the best thing to replace this with? I couldn't find anything that was 1" x 2 1/4 or 1" x 2" either.
J187 is offline   Reply With Quote
Old 05-05-2011, 03:28 PM   #2
try looking at brickmold, thats used on exterior doors and windows a lot. they should have it at the big box stores. also they do make pvc moldings, see if they have anything in that that would work. it will never rot.
this is the brick molding: http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
this stuff is pvc and 3/4x2-1/2 maybe you could cut this and make it work
Old 05-05-2011, 04:42 PM   #3
kwikfishron's Avatar
Rewards Points: 430
What you need is a table saw, a router and make the trim.
You won’t find those dimensions on the shelf.
kwikfishron is offline   Reply With Quote
Old 05-05-2011, 05:26 PM   #4
Rewards Points: 5,336
They make a composite material you can use to replace the material you have now. It comes in various widths and thicknesses. Buy what you need and fabricate the profiles that match.
Ron
Old 05-06-2011, 07:51 PM   #5
Rewards Points: 150
I agree with pvc brickmold. I used it around my exterior doors after removing rotted wood like yours and I love it.
guest is offline   Reply With Quote
Exterior Trim Options - What to use mlowrie Building & Construction 15 02-25-2011 11:59 PM
To Replace Doors and Trim or Not Ptron Carpentry 22 02-12-2011 10:20 PM
choosing right bulb and trim kit combo for recessed windowguy Electrical 3 11-29-2009 03:17 PM
Removing latex paint from wood trim ulbass Painting 1 03-12-2009 01:19 PM
Painting fireplace & trim? bltwa Interior Decorating 4 03-08-2009 01:57 AM
