Need To Rebuild Outside Steps And Walls Coming From Basement - Building & Construction - Page 3 - DIY Chatroom Home Improvement Forum
Old 05-02-2010, 12:55 PM   #31
Concrete & Masonry
Rewards Points: 470
Originally Posted by doug123 View Post
jomama45 - I found a versa-lok dealer actually pretty close to my house. Just got back. They were closed but they had some samples outside. Really nice, I think I am like 90% sure I am going with that.
Had a question for you if you don't mind, seems like you do this a lot.
Scuba_Dave suggested earlier that I rip out the left side wall and steps and I should leave the right side for last.
So that is pretty much what I plan on doing.
Do you think I'd have any problem doing it that way with the versa lok?
I might even leave the right side wall up for awhile and replace it later if that is an option.
What do you think?
Thanks!!!
Personally, I would do it all right away, mostly because I would want to interlock (weave) the 3 walls together at the corners. This will create a stronger structure, & may even be easier to carry your heights through accuritely.
Make sure to spend your time educating yourself off of the installation cross-section PDF's available through Versa-lok, and this should be a fairly simple, but laborious, project.
And, work on adding a second railing on that upper staircase, not real safe how it is now with the additional drop into the basement stairwell.
jomama45 is offline   Reply With Quote
Old 05-03-2010, 08:45 AM   #32
One more thing please. I've been studying up some. Still have some more to look at but just had a question.
Once the pins are in, how hard is it to get back apart? Not that I would want to take it apart, but since this is my first time.
Say I did something then an hour later thought, Dang! I should have done this instead.
Can I get them back apart?
Thanks!
doug123 is offline   Reply With Quote
steps to finish my basement DrewB Remodeling 1 01-28-2010 02:33 PM
Moving ductwork to accomodate finished basement Badfish740 HVAC 1 01-13-2010 04:11 PM
Insulate/air seal shared walls in townhome? RebornRenov Building & Construction 4 01-07-2010 10:50 AM
water pouring into basement from around water supply line matty8199 Building & Construction 29 12-29-2009 06:07 PM
Odd basement leak - from the outside walls DyerWolf General DIY Discussions 3 05-08-2007 07:17 AM
