Need Quick Carpenter Question Please? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-06-2010, 09:58 AM   #1
Need quick Carpenter question please?
Hello- I am having a shop framed as we speak and noticed a gap between the sill plate and wall plate. The bottom of the wall is gapped by the thickness of the 3"x3" washer that bolts down the sill plate on the j-bolt.
Let me try to explain again: The perimeter walls are built on top of a concrete stem wall with j-bolts sticking up. The heavy washer is between the pt sill plate and the wall bottom plate....so the wall does not sit down flush it is gapped about 1/4" by this heavy washer everywhere there is a j-bolt.
saltydogg is offline   Reply With Quote
Old 08-06-2010, 11:46 AM   #2
hey salty.
sounds like you have double bottom plate, but the second one isn't bolted down?
the j-bolt should be going through both the PT and the regular plate with the washer and nut on top. i don't think there should be a gap, and there's no reason there should be a washer between the two plates.
wombosi is offline   Reply With Quote
Old 08-06-2010, 01:05 PM   #3
jlhaslip's Avatar
Rewards Points: 2,884
You could try a foam sill gasket added on top of the concrete, under the plate to stop the wind from blowing through.
Notch for the washers between plates?
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 08-06-2010, 01:14 PM   #4
Mold!! Let's kill it!
Rewards Points: 2,012
In your case, the framer should notch the wall plate down over the washers. Otherwise the wall framing is supported on top of the washers and will sag over time.
Old 08-06-2010, 02:28 PM   #5
Tizzer's Avatar
Rewards Points: 470
Sounds like it's too late to do anything about it other than have the framer lay the walls back down and notch them correctly.
A 3 inch washer is huge, things must have changed since I framed.
Tizzer is offline   Reply With Quote
Old 08-06-2010, 02:31 PM   #6
Registered User
Rewards Points: 526
The last few posts are right on! Sill sealer for a capillary and thermal break. Over-sized hole drilled for the bolt/nut with a fan recess for the washer in the 2nd bottom plate. Framer holds the saw up with just the front shoe resting on plate, starts saw with just 3/8" deep blade into work as moving side to side (fan) to remove material for washer. OR, cut a diamond shape out for the bolt/nut with a fan for the washer.
The bolt only goes through one plate, the p.t. bottom one, to install washer and nut there getting the proper depth embedded of the remainder of "J" bolt in the concrete. The washer and nut is required on the bottom plate for the up-lift force resistance, per code.
http://www.greenbuildingadvisor.com/...-building-code
Be safe, Gary
tile backsplash question - quick please momof2labs General DIY Discussions 3 05-29-2010 12:10 PM
wall oven wiring quick question 205bhamjim Electrical 3 11-17-2009 03:01 PM
Quick question about a P-Trap under a toilet zaphood Plumbing 6 03-28-2009 09:20 AM
Quick Question needsomeanswers Building & Construction 4 09-01-2008 09:45 AM
framing an awning...quick question sjrhome Building & Construction 7 12-03-2006 11:24 AM
