Need Opinions On Insulation Of Basement Walls - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-28-2011, 10:15 AM   #1
Need opinions on insulation of basement walls
My basement has finished walls, but no insulation at all. The basment is all concrete walls and has never had water. I have a french drain around the basement with a sump pump. I want to insulate as the room is chilly during the winter and gets warm with 5+ people in the summer. I have 1 6" hit from my forced air heat/ac system in the back of the room that has made a difference, but it not enough. I also have an electric fireplace i use during really cold days to take the chill out of the room. I have 2 outside walls as i am in a middle unit townhouse. one of the walls i can physically get behind to insulate with r13 rolls, but the other outside wall i can not get behind. I do have access through the sump pump access and i can remove my deck steps and a ledger board to get to it from the outside. I was thinking about blown insulation, but i am nervous should i get water, or the moisture in the concrete is not allowed breathe and cause mold. I was told i should rip the drywall down, insulate with r13 and put the wall back up but i was hoping there was an easier way. Also will insulating the outside walls only make a difference if the 2 common walls and floor are not insulated?
mstemphoski is offline   Reply With Quote
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 07:40 AM
Townhouse basement insulation benb Building & Construction 0 02-15-2011 09:32 AM
Finishing Basement Walls, Inside Perimeter Drains, and Moisture, Oh My BSponz1 Building & Construction 1 02-08-2011 01:20 PM
Insulation of interior walls around fire place ODD Calmeier Building & Construction 5 01-31-2010 05:59 PM
basement insulation - condensation behind the batt insulation natalie Building & Construction 3 01-31-2010 10:19 AM
