Need Nickle Screws For Front Door Hinge - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-05-2010, 06:56 PM   #1
Orca
orca's Avatar
Need Nickle screws for front door hinge
I have a new home and the top hinge has 5 of the eight screw holes stripped. The screws screw in but don't get tight. The length is 3/4" long. I guess I could install dowels in the holes (after I drill them larger) but I wanted to install longer screws as that would be easier. The problem I am having is locating longer nickle screws. Is 3/4" long the only ones that are available? I think they are a #8 flathead screw.
orca is offline   Reply With Quote
Old 06-05-2010, 07:10 PM   #2
kwikfishron's Avatar
Rewards Points: 1,002
Most new pre-hung doors come with 1-3 longer screws in the finish (nickel or brass) so you can connect the hinges to the house framing. That said, any door supplier "can" order the screws your looking for.
Forget the box stores, they have their apron strings on to tight to figure it out.
Even a good hardware store can get confused.
Go to your well established local lumber yard's contractors desk, they can hook you up.
I say “go to the contractors desk” because their the vet's in the store. The guy/gal at the register probably doesn’t have a clue.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
orca (06-05-2010)
Old 06-05-2010, 09:15 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,726
Ayuh,... A wooden match,+ a spot of glue will Fix the holes....
Then reuse the screws you have...
The Following User Says Thank You to Bondo For This Useful Post:
orca (06-05-2010)
Old 06-05-2010, 09:21 PM   #4
Registered User
Rewards Points: 526
Home Depot has them in 1-3/4", both finishes. Across the aisle from the locksets.
Be safe, Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
orca (06-05-2010)
Old 06-05-2010, 10:07 PM   #5
Orca
orca's Avatar
Tried a toothpick first and that was no good. This just seems to be a short term fix. Thanks for helping.
Composite vs wood deck screws cranedk Building & Construction 6 11-26-2015 03:47 PM
I can't get tapcon screws to tap into the concrete slab!? Monty Building & Construction 24 08-07-2010 07:08 AM
Stainless steel deck screws and hardibacker johnknez Building & Construction 1 10-09-2009 08:56 AM
New Drywall Installation, 1 joint screws are popping zjowens Drywall & Plaster 29 01-02-2009 12:26 AM
Screws vs Nails in Interior framing project alexz Building & Construction 2 07-05-2006 05:58 AM
