Need To Make Up 4" With A Glass Block Window. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-18-2013, 09:14 PM   #1
Need to make up 4" with a glass block window.
I got a window opening, brick, 27 3/4" wide. It is going to be in a shower.
Only combination of glass blocks I can come up with is 24" wide... 8" blocks..
I thought about making the mortar joints bigger but they would end up being an inch wide...
What can do to make up the gaps? I thought of having stone cut or something to mortar in...
Anyone have any ideas?
JimL is offline   Reply With Quote
Old 08-19-2013, 06:03 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,554
Spreading the mortar joints is going to look funky and a good chance of uneven.
Either put in a picture window of that size or trim out the sizes with some decorative trim to hid the gaps at the edges of the frame out.
Old 08-19-2013, 06:16 AM   #3
Concrete & Masonry
Rewards Points: 636
Why not just use a 4" x 8" glass block?
jomama45 is offline   Reply With Quote
Old 08-19-2013, 07:09 AM   #4
DIY staff
Rewards Points: 7,174
Just a tip----most brick yards will make up the window for you and add a steel band so you can install the blocks as a unit,----makes block windows fast and easy to install----Mike----
Old 08-19-2013, 09:22 AM   #5
Rewards Points: 676
Why not build it in your garage in a 2' x 4' or 2' x 6' treated board that you can them set in place? That is what I did for my basement 18" x 36" that is in the shower area.
I bought my supplies from one of the big box stores and used a silicon glass block adhesive to hold it all together, along with the proper spacers, anchors, etc.
B
Beepster is offline   Reply With Quote
Take glass out of vinyl window to make chicken coop window igapo General DIY Discussions 6 04-01-2013 10:17 AM
Glass Block Window Install dvaupel Windows and Doors 3 10-03-2011 10:13 PM
Weight of Glass Block Window jonathan03 Remodeling 2 06-23-2010 11:21 AM
glass block window Morjade Building & Construction 1 04-23-2009 06:32 PM
rough opening for glass block oxicottin Remodeling 5 05-04-2008 08:01 PM
