Need To Install Hand Rail On Basement Stairs, But On Concrete Wall - Building & Construction - Page 3 - DIY Chatroom Home Improvement Forum
Old 01-11-2012, 09:28 AM   #31
Thank you Epson!
That is what I thought I would have to do...I think I will use an acorn bolt on the top for asthetics....sound ok?
emarti22 is offline   Reply With Quote
Old 01-11-2012, 10:08 PM   #32
Rewards Points: 2,202
Acorn nut should workfine. Have to have right amount of threads sticking out. Too much an you nut won't get tight or it will break off the acorn, to little and the nut does not grip enough threads.
Use some Loctite on the treads.
mae-ling is offline   Reply With Quote
Old 01-11-2012, 11:33 PM   #33
Rewards Points: 558
You mean putting it on the wedge anchor with the nut and washer and then finishing it off with an acorn nut? If so, just for aesthetics yes but with such little thread on the acorn nut it will fall off in time. On another note if you intend to remove this handrail sometime in the future for moving purposes please donít apply any permanent adhesive to the acorn nut.
here are some sample acorn nuts: http://www.chromebolt.com/acorn-nut-c-54.html
epson is offline   Reply With Quote
Old 01-11-2012, 11:58 PM   #34
That is why I recommend the medium strength, can still remove it. Would the acorn nut work without the regular nut under it, Just a washer and then the acorn nut? Maybe not strong enough?
Old 01-12-2012, 12:21 AM   #35
Rewards Points: 558
The acorn nut does not have enough thread to do what the intended anchor is used for. It can only be used as an aesthetic nut to hide the thread. And yes you can use the medium strength loctite 243 to secure the acorn nut. But once itís on you can only remove it with hand tools and when removed you have to clean or should clean the remaining loctite on the thread before reapplying.
The Following User Says Thank You to epson For This Useful Post:
mae-ling (01-12-2012)
Old 01-12-2012, 12:25 AM   #36
There are plastic caps that go on over a nut. http://www.google.ca/search?q=plasti...EumciQLXqYDgDQ
Old 01-12-2012, 12:42 AM   #37
Rewards Points: 558
Yes I know all about those. Each and every one of those covers survives a different purpose for a different application and if you want to use it in this type of application go right ahead. But it will only be serving as an aesthetic finish thatís all. The strength is in the wedge anchor and how it is applied to the handrail.
Old 01-12-2012, 12:50 AM   #38
I think they want it to look good as well as be strong.
Old 01-12-2012, 01:07 AM   #39
Rewards Points: 558
Yes I can understand that, but this handrail is going to be mounted on a concrete wall going to the basement. Now unless her basement is finished and she wants to cover the exposed screwís she can, if not, there is nothing wrong with leaving it as is.
Old 01-17-2012, 03:21 PM   #40
Thank you both!
I am installing going in to the basement. I am trying to make it look really nice because we are finishing the basement in to an apartment.
SO, I am looking to use a 1/4 inch diameter anchor (how long should I go?) and then put on the washer and nut that came with it....and THEN put on one of those caps right?
Any suggestion where I can buy all this (and not in sets of 100?) I only need three:-)
I appreciate all this help!! I think my handrail will look really great when I am done!
Old 01-18-2012, 09:33 AM   #41
In our area stairs to finished basements require guards on the open (unprotected) side ie pickets . Not sure if it applies in your district but you might want to check.
Marvel is offline   Reply With Quote
A glue that works on precast concrete wall wildwings Building & Construction 5 12-30-2010 09:34 AM
Need help with how to mount porch light to concrete foundation wall wherm5150 Electrical 7 11-16-2010 09:56 PM
Attaching a worksurface directly to studs in of a basement wall BasementVirgin Building & Construction 3 10-06-2010 01:04 PM
Will water lines freeze if placed behind insulated stud wall in basement? jpsmith Remodeling 22 03-05-2009 01:23 PM
Concrete walkup stairs from the basement handy man88 Building & Construction 3 09-08-2008 06:05 PM
