Need Ideas For Shed Door Prop - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-10-2012, 05:18 AM   #16
kwikfishron's Avatar
Rewards Points: 620
Originally Posted by nikeman View Post
I have about half a bag of fast setting quickrete in my shed. My plan is to just pound the metal pipe I bought into the ground with a mallet. I bought a 4' long 1/2" diameter pipe. How can I get concrete in such a small hoe?
Your a bag should be perfect for this.
Youll have to dig a hole, 6 or so in diameter and maybe 18 deep.
Depending on your soil 4 maybe a little long to pound in a pipe accurately enough to receive the pin, Id probably cut it down some.
Dig the hole, pound in the pipe just enough to hold it in place then mix and pour the concrete around it.
kwikfishron is online now   Reply With Quote
Old 06-10-2012, 08:10 AM   #17
Rewards Points: 590
Originally Posted by ktkelly
I agree with this.
In your response you say you don't want to put a hole in the siding. Well, you don't have to.
Use a couple self tapping screws to hold an "eye" on the upper part of the door, and mount the hook to the top of the jamb.
Open door, swing hook up and place it in the eye.
Everything is inside and out of the way....
The problem with that is the shed has 8' walls and that part sits about 1' above the ground. I can't reach 9' with a running start. Also, the door is metal.
nikeman is offline   Reply With Quote
Old 06-10-2012, 09:33 AM   #18
Rewards Points: 502
Why not get a long-pin stay, and just let it fall in the dirt/gravel. You don't need pipes casting in concrete; they only fill up with dirt over time and get blocked up.
Need ideas for shed door prop-dscf3614.jpg   Need ideas for shed door prop-dscf3615.jpg
tony.g is offline   Reply With Quote
Old 06-10-2012, 05:00 PM   #19
Rewards Points: 590
My doors are metal and have a pin built in on top and bottom. I just finished this project up actually. I pounded a 2' long 3/4" PVC pipe with the bottom blocked off flush to the ground. Then I cut the 1/2" metal pipe down to size. It works like a charm. I was surprised I lined it all up on my first try! I have a broken corner piece from a cinder block laying on top of pipe in the ground while I'm not using it.
Old 06-10-2012, 06:11 PM   #20
Rewards Points: 1,470
Although I know you've finished the job, I must say:
I doubt that the doors go all the way up to the 8' wall, and you wouldn't have been outside on ground level went placing the hook into the eye.
But a running start and a healthy jump would probably have worked anyway....
The mental image of that just exercise brought a tear to my eye.
ktkelly is offline   Reply With Quote
Old 06-10-2012, 07:27 PM   #21
DIY staff
Rewards Points: 7,174
As light as that door is---you could fill a flower pot with concrete--add a stub of pipe for the door catch and be done in a hurry.
Loft bedroom ideas! Help! Alexz7272 Interior Decorating 5 12-31-2011 09:10 PM
Redecorating DD's room....thoughts, ideas? Looong. RealHouswifOfOK Interior Decorating 14 04-22-2011 06:19 PM
Loo9king forward to ideas nanalane9 Introductions 3 03-25-2011 08:07 AM
Garage shelving ideas koodawg General DIY Discussions 3 12-31-2010 09:52 AM
Ideas needed for kitchen reno (pic included) bearcats23 General DIY Discussions 5 05-24-2010 08:36 PM
