Need Ideas For Shed Door Prop - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-09-2012, 01:52 PM   #1
Rewards Points: 588
Have a double out swinging door on my shed and the left door won't stay open on its own. It has pins that keeps it closed while the other door opens and closes freely. I want to use one of the pins to prop it open when I want to. Any ideas? I was thinking some sort of small metal pipe in the ground that sticks up high enough so that pin can fall in it or something similar up top with the top pin.
nikeman is offline   Reply With Quote
Old 06-09-2012, 05:29 PM   #2
DIY staff
Rewards Points: 7,174
A pipe or wood post sunk into the ground there is all you need---
Old 06-09-2012, 05:37 PM   #3
Rewards Points: 588
If I pound a pipe into the ground how do I prevent it from moving around? I have in mind a pipe they use for fences but with a pipe inside of it to stick out and reach the door pin.
Old 06-09-2012, 05:40 PM   #4
DIY staff
Use a stiff pipe---drive it about 3 feet in---a block and pipe clamp screwed into the framing under the siding could also add some stiffness.
Old 06-09-2012, 08:14 PM   #5
kwikfishron's Avatar
Rewards Points: 86
So could a $5 bag of ready mix.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
oh'mike (06-09-2012)
Old 06-09-2012, 09:21 PM   #6
Rewards Points: 588
I have about half a bag of fast setting quickrete in my shed. My plan is to just pound the metal pipe I bought into the ground with a mallet. I bought a 4' long 1/2" diameter pipe. How can I get concrete in such a small hoe?
Old 06-09-2012, 09:48 PM   #7
DIY staff
If the pipe alone is to floppy--cut the bottom out of a small bucket or pail---place that around the pipe like a collar---then pack that with your concrete---that 'collar ' should be all you need to take the flex out of the pipe.
Old 06-09-2012, 10:00 PM   #8
Rewards Points: 588
The pipe is metal so it's not floppy at all I just worry about the hole in the ground will get bigger and bigger over time and lean or fall over. It
Old 06-09-2012, 10:01 PM   #9
Rewards Points: 588
The pipe is metal so it's not floppy at all I just worry about the hole in the ground will get bigger and bigger over time and lean or fall over. It would be nice to be able to take the pipe out of the ground when I'm not using it.
Old 06-09-2012, 10:15 PM   #10
DIY staff
You could dig a hole and set that collar at ground level after you drive the pipe into position.
Old 06-09-2012, 10:38 PM   #11
Can't you just put a simple little hook on the door and an eye on the shed
creeper is offline   Reply With Quote
Old 06-09-2012, 10:48 PM   #12
Rewards Points: 588
What if I got a larger metal pipe and hammered it all the way flush to the ground and filled it with gravel until i can put the smaller pipe inside it and it sticks up high enough for the door pin to go in? Does that make sense? Maybe I'll leave the bigger pipe about an inch above ground so dirt and mud doesn't get in it all the time.
I always worry about myself or someone else falling on something that's sticking out of the ground which is why I want to be able to take it out when nor in use.
Old 06-09-2012, 10:49 PM   #13
Rewards Points: 588
I have vinyl siding that I do not want to put a hole in. Also, the door is metal. That would have been done already if I could.
Old 06-10-2012, 12:14 AM   #14
Rewards Points: 1,450
I agree with this.
In your response you say you don't want to put a hole in the siding. Well, you don't have to.
Use a couple self tapping screws to hold an "eye" on the upper part of the door, and mount the hook to the top of the jamb.
Open door, swing hook up and place it in the eye.
Everything is inside and out of the way....
ktkelly is offline   Reply With Quote
Old 06-10-2012, 12:15 AM   #15
Rewards Points: 150
is it possible to adjust the hinges with shims and/or tighten up the hinge pin (bending it very slightly, to give hinge more friction) to keep the door open on its own? My shed, the wind would blow the door shut so I used the hook and eye method to hold it open. I often thought about installing a kickstand on the door; but then we sold the house and the shed was no longer mine....
silversport is offline   Reply With Quote
Loft bedroom ideas! Help! Alexz7272 Interior Decorating 5 12-31-2011 10:10 PM
Redecorating DD's room....thoughts, ideas? Looong. RealHouswifOfOK Interior Decorating 14 04-22-2011 07:19 PM
Loo9king forward to ideas nanalane9 Introductions 3 03-25-2011 09:07 AM
Garage shelving ideas koodawg General DIY Discussions 3 12-31-2010 10:52 AM
Ideas needed for kitchen reno (pic included) bearcats23 General DIY Discussions 5 05-24-2010 09:36 PM
