Need Ideas On How To Fur Out This Basement Entry Door - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-05-2013, 01:43 PM   #1
crankcase's Avatar
Need ideas on how to fur out this basement entry door
I'm Furring my exterior walls with 2x2's and I'm puzzled on how to go about the area at this entry door from the garage. The block wall has 1.5" Thermax glued to the blocking. Do I just install an extension jam out to the interior side of my 2x2 furring plus 1/2" for drywall and frame in the top to match? There is nothing solid to shim and nail an extension jam to now just foam.
crankcase is offline   Reply With Quote
Old 03-05-2013, 05:18 PM   #2
Rewards Points: 150
First off how is the hinge side of your down only fastened to foam. I would do treated lumber on bottom plate with foam under.
kaschmid3 is offline   Reply With Quote
Old 03-05-2013, 05:54 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,276
Remove the door & frame and reinstall flush with the furred out wall. Install the extension jambs on the exterior.
Coastal South Carolina
Old 03-05-2013, 06:44 PM   #4
kwikfishron's Avatar
Rewards Points: 1,018
+1 except it should be flush with the interior "finished" wall (Sheetrock or whatever).
Crankcase... if you don't move the door in it won't be able to open much more than 90 deg. making it real easy for someone to rip the door off the hinges.
kwikfishron is online now   Reply With Quote
Old 03-06-2013, 10:54 AM   #5
crankcase's Avatar
On the hinge side it looks like the builder ripped some OSB and must have used Tapcons into the block, then shimmed and nailed into the OSB. The foamboard just returns and stops at the interior side of the door I assume.
Old 03-06-2013, 11:09 AM   #6
crankcase's Avatar
Good point. I would think I would remove all foam on the jam sides, then throw up some VB and Tapcon treated 3/4 or treated ply attached to the block flush with the interior finished wall. Then add extensions to the exterior side.
I think the door bottom is just sitting on concrete should I just caulk or use a sill seal at all? The basement floor is heated, I dont think there is a thermal break. just a cold joint at the stair bottom I wont know till I pull out the door.
Door recommendations from basement to garage Tyrus3 Building & Construction 7 07-20-2012 08:12 AM
Ideas to hide/incorporate an unsightly bilco door in landscaping v0099 Landscaping & Lawn Care 2 03-30-2011 11:14 AM
How to make basement door more secure? doublesharp Building & Construction 11 11-27-2009 06:20 AM
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 03:01 AM
Entry Door---My Story----Advice Please rossmoor Building & Construction 3 02-29-2008 09:13 PM
