Old 12-20-2012, 02:00 PM   #1
Need help with zip line
Purchased 90 foot zip line for my son. Do not have trees to attach. Was planning on buying 4x4x12 post from lowes and putting 4 foot in ground and having 8 foot above. Called manufactor of zip line and they said I need at least 12" diameter to attach to. Their experience is that 4x4 and 4x6 post will bend over time. My question is, if I attache 2 posts together, and then bury it in concrete, will that double the strength and keep the posts from bending...thanks
Jack121883 is offline   Reply With Quote
Old 12-20-2012, 02:49 PM   #2
No. And please check with your insurance company before proceeding. They may drop your coverage if you install a zip line on your property. That was quite common years ago when trampolines were all the rage.
Old 12-20-2012, 10:12 PM   #3
If I am reading your post correctly, are you suggesting to go against your manufacturer's instruction/recommendation?
Sorry, I can't help you much more...
Just be careful...
oodssoo is offline   Reply With Quote
Old 12-21-2012, 12:16 AM   #4
Semi-Pro Electro-Geek
4X4 is way too small, and using two of them is still not even close. If you want to build a suitable endpoint for the zip line using lumber (rather than heavy timber or a live tree) you will need to build some kind of frame. Three anchor points would be the minimum, I think, since you need rigidity in two directions. Planting a section of utility pole would probably be easier and cheaper, even if you contract a drilling company to make the hole.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 12-21-2012, 12:19 AM   #5
Exactly, I was just going to suggest a utility pole, should be plenty beefy enough
mterry is offline   Reply With Quote
Old 12-21-2012, 02:41 PM   #6
I suggest you return the zip line and buy your son a bicycle instead. Or an electric train. Even if your insurance company doesn't cancel you, your premium will surely go up just because of the liability.
Old 12-21-2012, 04:06 PM   #7
I say go for it and let natural selection run its course. Do you have any big pieces of fireworks you or your son can carry while zipping down the line?
B
Beepster is offline   Reply With Quote
The Following User Says Thank You to Beepster For This Useful Post:
memarybe (12-21-2012)
Old 12-23-2012, 05:58 AM   #8
count me in as a supporter of natural selection, too,,, got to happen sometime,,, otherwise he'd know 4 x 4's are akin to matchsticks - unless he's an atty, of course no motorcycle helmets, either,,, show me where the world is a better place because of gary busey
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders !
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help
itsreallyconc is offline   Reply With Quote
Complete blockage of main line mnp13 Plumbing 9 05-29-2012 11:51 AM
Adding a second line to existing septic line Eddietan Plumbing 3 05-10-2012 10:27 AM
Old water supply line a_lost_shadow Plumbing 7 04-20-2012 12:12 AM
Condensate Drain Line Mystery (pan full but no primary clog?) CarrieLP HVAC 21 04-05-2012 12:07 AM
Capacity loss with line size Einride HVAC 1 06-29-2009 04:10 PM
