Need Help Water Problem In The Wall - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-07-2012, 06:46 PM   #16
Chicago, IL
Michael Thomas's Avatar
Originally Posted by ironman_troop View Post
MAT test - can you elaborate, what that means?
RILEM (MATS) testing
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 11-08-2012, 12:52 PM   #17
Mold!! Let's kill it!
Rewards Points: 2,012
I would have a real close look at the vent penetrations through the roof. Niether of them look like they have a good flashing detail applied to them. The link will show you a detail approved by the NRCA for vent stack flashing on a built up roof.
http://www.nrca.net/consumer/types/details/bur-18.pdf
Any water that is entering around the vents could travel under the flat roof to the perimeter of the deck and down the wall.
Also make sure that the metal cap on the top of the wall is not your only water barrier. Those metal caps are made of pieces usually 8-10 feet long. They expand and contract and usually open up at the seams. Many times the only water barrier at the seams is a caulk joint. The flashing from the roof surface should run up and across the top of the parapet wall to the outside edge. The metal cap should only be there to protect the flashing, not to act as a water barrier.
Old 11-12-2012, 10:06 AM   #18
Thank you
Hi all,
Thank you for all your inputs...
Few days a go we had an extreme rain, wind and hail and with the cmu wall is exposed.. I didn't find any water run or mark.. so the only thing I can come out is on vapor and condentation on the CMU blocks... I will water proof the cmu and use pt wood as stud (furring) and green board or moister retardant board and finish it..
Let me know what you final thoughts..
ironman_troop is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Water issue in bathroom at base of the tub and shower plumbing wall NeverEnoughTime Plumbing 3 10-24-2012 11:23 PM
Whole in Crawl Space Wall? Water Problem? - Picture! donaldp General DIY Discussions 1 03-26-2010 08:52 PM
Will water lines freeze if placed behind insulated stud wall in basement? jpsmith Remodeling 22 03-05-2009 12:23 PM
