NEED HELP!! Threshold Fastener Head Snapping Off In Concrete For Storefront Door - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-05-2013, 11:51 PM   #1
Exclamation
NEED HELP!! Threshold fastener head snapping off in concrete for storefront door
I have a banquet hall and i'm doing some renovations to the place. I have to lower the threshold down b/c it's not to code as the code requires it be no more than a 1/2" elevation from the floor and the five doors that i have are all above that. (the building management will not take care of it). SO.. the fasteners they installed seem to be 4" tapcon screws (overkill). Most of them are seized in the concrete, I've already snapped 2 heads off and i'm at a loss as to how to take the stubborn SOBs out. I was able to take out one and it was pretty rusty. I need them out so i can reinstall the threshold in the same location and not have to make a hole at an incline as the screw head will most likely rip the door shoe rubber sweep i'm installing to close the gap that i'll create in lowering the threshold (also pretty sure the inspector wont like it). I need to know how to take out the fasteners without snapping them and to remove the ones that are snapped. Any information would extremely help. Thanks
Aleko is offline   Reply With Quote
Old 03-06-2013, 12:00 AM   #2
Rewards Points: 12,794
Most likly that's not going to happen.
Got a picture or a website of the one your going to put in?
Most have to be cut to fit. Just figure out how to make the cuts so the new holes do not line up where the old ones where.
Old 03-06-2013, 12:18 AM   #3
No, no pictures. I'm not replacing just lowering the existing threshold. I also forgot the mention the concrete is level. The building was supposed to have tile on the outside but it was never done (don't know how it past inspection). That's why the threshold is elevated past code.
Old 03-06-2013, 07:34 AM   #4
Rewards Points: 3,130
Joecaption is right. Don't reuse that threshold, replace it. Cut the new one so that the screw holes will be in a different location. Drill new holes. With the proper bit, drilling in concrete isn't that hard.
Entry door adjustable threshold JLars Carpentry 3 02-12-2013 11:07 AM
Concrete Basics for the DIYer Mort Concrete, Stone & Masonry 7 11-22-2012 12:19 PM
Mahogany Door Jamb - What nails and where? Toronto Carpentry 25 07-26-2012 08:08 PM
Caulking Inside of Shower Door Threshold arigsby Plumbing 5 03-10-2012 03:00 PM
Marble Threshold too High with concrete board amgdiy Flooring 6 02-01-2012 08:24 PM
