Need Help Securing Trim At Top Of Stairs - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-03-2013, 10:29 AM   #1
Rav
Rewards Points: 542
Need help securing trim at top of stairs
Hopefully this is the correct forum for this. There is a piece of narrow wood trim at the top of the stairs from our basement which keeps starting to pull away (horizontally) from the floor, causing a gap. As the gap widens, I hammer the piece back and hammer back the existing nails, such as they are, that are holding it in (put in by the previous owner). I want to secure this piece so that it stays in place.
I assume some sort of nails are the solution, but I'm a total newbie in this area. What type of nails? What size (length, diameter)? In order not to crack the wood, should I drill holes first? What size bit?
I've included three pics: An overview, a closeup, and a side-view.
Thanks!
Need help securing trim at top of stairs-overview.jpg   Need help securing trim at top of stairs-closeup.jpg   Need help securing trim at top of stairs-sideview.jpg
Rav is offline   Reply With Quote
Old 02-03-2013, 10:44 AM   #2
kwikfishron's Avatar
Rewards Points: 86
Just remove the piece, make sure the surfaces are clean and glue it back down. Any yellow wood glue should wood glue should work fine.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
Rav (02-03-2013)
Old 02-03-2013, 10:47 AM   #3
DIY staff
Rewards Points: 7,174
Wrong trim--that's why it won't stay put----You need a stair nosing----that will have enough surface area to be glued or nailed without coming loose like that.
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
Rav (02-03-2013), woodworkbykirk (02-03-2013)
Old 02-03-2013, 10:47 AM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
The only two things that come to mind right off hand is, open the crack and fill with epoxy glue. Also if it were mine I would drill a 3/8 inch wide hole just deep enough for a dowel, then drill a pilot for a screw, screw it tight and plug the hole, it should hold then.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
Rav (02-03-2013)
Old 02-03-2013, 10:47 AM   #5
DIY staff
Rav (02-03-2013)
Old 02-03-2013, 10:50 AM   #6
Rewards Points: 12,818
There was suppost to be a landing tread there instead.
http://www.bing.com/images/search?q=...electedIndex=0
Rav (02-03-2013)
Old 02-03-2013, 11:16 AM   #7
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
Originally Posted by oh'mike View Post
Man, talk about feeling stupid and I am a stair guy, or was. Why didn't I think of that.
Jim
Old 02-03-2013, 12:00 PM   #8
DIY staff
You are forgiven---You have been digging and everyone knows that can affect the memory---the devil invented shovels to make life miserable.
Old 02-03-2013, 07:42 PM   #9
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
Man, ain't that the truth.
Jim
oh'mike (02-04-2013)
Tags
securing , stair , trim
Current house - stairs JulieB Project Showcase 20 04-09-2013 02:38 PM
Picture Frame trim on stairs xemon2000 Carpentry 7 10-08-2012 11:37 AM
Suggestions on finishing on trim for stairs - photos theedudenator Carpentry 4 12-19-2010 07:51 PM
Help with staining my stairs kimber Flooring 2 12-04-2009 08:45 PM
Strengthening stairs with less support HitLines Remodeling 1 10-30-2009 12:45 AM
