-   -   Need help securing trim at top of stairs (http://www.diychatroom.com/f19/need-help-securing-trim-top-stairs-170889/)
Rav 02-03-2013 10:29 AM
3 Attachment(s)
Hopefully this is the correct forum for this. There is a piece of narrow wood trim at the top of the stairs from our basement which keeps starting to pull away (horizontally) from the floor, causing a gap. As the gap widens, I hammer the piece back and hammer back the existing nails, such as they are, that are holding it in (put in by the previous owner). I want to secure this piece so that it stays in place.
I assume some sort of nails are the solution, but I'm a total newbie in this area. What type of nails? What size (length, diameter)? In order not to crack the wood, should I drill holes first? What size bit?
I've included three pics: An overview, a closeup, and a side-view.
Thanks!
kwikfishron 02-03-2013 10:44 AM
199 Attachment(s)
Just remove the piece, make sure the surfaces are clean and glue it back down. Any yellow wood glue should wood glue should work fine.
oh'mike 02-03-2013 10:47 AM
Wrong trim--that's why it won't stay put----You need a stair nosing----that will have enough surface area to be glued or nailed without coming loose like that.
http://www.diychatroom.com/data:imag...AAAAAAAAf/2Q==
BigJim 02-03-2013 10:47 AM
The only two things that come to mind right off hand is, open the crack and fill with epoxy glue. Also if it were mine I would drill a 3/8 inch wide hole just deep enough for a dowel, then drill a pilot for a screw, screw it tight and plug the hole, it should hold then.
https://encrypted-tbn3.gstatic.com/i...F1OLRuyhpii9uahttp://www.diychatroom.com/data:imag...AAAAAAAAf/2Q==
joecaption 02-03-2013 10:50 AM
There was suppost to be a landing tread there instead.
http://www.bing.com/images/search?q=...electedIndex=0
BigJim 02-03-2013 11:16 AM
Man, talk about feeling stupid and I am a stair guy, or was.:eek: Why didn't I think of that.
oh'mike 02-03-2013 12:00 PM
You are forgiven---You have been digging and everyone knows that can affect the memory---the devil invented shovels to make life miserable.
BigJim 02-03-2013 07:42 PM
Man, ain't that the truth.:)
