Need Help Sealing Foundation Leak (townhouse) - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-07-2012, 10:25 AM   #16
Rewards Points: 2,516
Try applying a siloxane based product to the brick veneer. Many people do not know that brick will absorb moisture. And the fact that you say on a HEAVY RAIN you still have a little water.
Do this spray some water on that brick veneer. Does the brick change color like gets darker? Then it is absorbing moisture.
Here is a product by Prosoco that I used. Its amazing. After applying it to the brick(vertical surface) then throwing water on the brick, the water beads up and rolls off like a newly waxed car.
http://www.prosoco.com/Products/d113...e-b0006e080476
hammerlane is offline   Reply With Quote
The Following User Says Thank You to hammerlane For This Useful Post:
RickDel (02-07-2012)
Old 02-07-2012, 03:14 PM   #17
Rewards Points: 4,726
we like prosoco too but there are others on the mkt
Old 02-07-2012, 03:25 PM   #18
Rewards Points: 123
Well guys, I actually used a silicone spray prior to cleaning the gutters. I can't recall the product name, but it was purchased at a contractor supply store and it was EXPENSIVE!! After I applied it, I couldn't really judge if it helped because of the gutter overflow problems; however, maybe I'll go back and reapply.
Honestly, since it's only a very, very, small fraction of infiltration, compared to before, I haven't worried too much about it.
RickDel is offline   Reply With Quote
Sealing pipe through block foundation kboorman General DIY Discussions 22 04-13-2015 07:51 PM
Sealing concrete foundation around water pipe shtoink Building & Construction 9 09-18-2009 05:15 PM
Sealing a concrete wall foundation richvoice Building & Construction 7 11-25-2008 02:55 PM
Darn. A leak in my main supply from street, Galvanized. In foundation under slab? twilightcall Plumbing 2 07-31-2008 12:22 AM
Leak in the cinder block foundation. 68MHJCs Building & Construction 7 01-25-2008 09:37 AM
