Need Help Replacing Screens In Windows - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-04-2010, 12:02 PM   #1
Need help replacing screens in windows
Hey all
I have some rather unusual screens in the windows of my home. they arnt the traditional pop out the screen frame, replace screen and pop back in to place.
i cant figure out how to take the screen frame out, if its even possible.
i can see the rubber seal cord that holds the screen in place on 3 sides. the bottom side of the screen seems to be enclosed by a piece of aluminum. cant figure out how to expose it WITHOUT bending the screen frame all up.
can anyone tell me how to replace my screens?
if it helps, the windows came with the house, built in 1994.
i am attaching some photos of the window. hopefully it helps.
window 1 is the overall shot of the window.
window 2 is the lower left of the window. if you look close, you can see the rubber seal on the left, the bottom has nothing cause it dissapears into the frame.
window 3 is the upper right corner. if you also notice you can see the black rubber seal on the top/right of the window
if you need additional photos, let me know and i will post them
Need help replacing screens in windows-window-1.jpg   Need help replacing screens in windows-window-2.jpg   Need help replacing screens in windows-window-3.jpg
reds_21 is offline   Reply With Quote
Old 09-04-2010, 02:58 PM   #2
fabrk8r
fabrk8r's Avatar
Is it possible the screens can be removed from inside the house after opening the loser sash. That's the way most screens that I've ever seen have to be removed.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 09-05-2010, 01:59 PM   #3
well, after looking at the window once again. it did have a lip on the inside that you can lift and it brings the whole screen frame up above the track and you just pull it out.
what was happening was that there was so much dirt, moths, and bugs in the track, that i couldnt move the screen enough to pop out. once i cleaned the track and the whole frame, all is good!!!!
screens have been replaced!!! thanks for that thought of it being on the inside!!!! i never had window screens like this.
learn something new everyday!!!
THANK YOU
Replacing Vinyl Windows w/o Nailing Fin irish Building & Construction 1 06-03-2010 10:37 AM
Replacing Windows? Kyle Remodeling 13 12-17-2009 07:03 PM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 12:18 PM
Replacing screens on Anderson windows sherwood Appliances 1 01-25-2009 02:42 PM
Replacing aluminum frame windows gallasm Remodeling 2 01-05-2009 10:03 AM
