Need Help With Patio Cover Supports - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-02-2007, 03:13 PM   #1
Need help with patio cover supports
I am installing a patio cover from dense shade cloth use a guy wire system. The cloth is to cover an are 13'x22'. I am using 1/4" galvanized steel rope with the normal hardware to bring it taught, unfortunately my redwood posts tend to bend quite a bit under the load. As I do not want to break the posts, or make them look like an archer's bow, I am unable to get the desired tension on the cables. I'm afraid without the necessary tension the wind will just take my shade cover for a ride.
My question is this, what other kinds of posts could I use that would be able to take the load? The posts will be around 8' out of the ground with the wires pulling towards the house at the tops via an eye bolt.
Please someone help me.
alexfosse is offline   Reply With Quote
Old 05-02-2007, 03:27 PM   #2
robertcdf's Avatar
6x6 or even 8x8 would probably do the trick... But they have to be set INTO the concrete at LEAST 3-4' and I would look at a hole at least 24" in diameter. This should help hold the tension.
However that size of redwood will cost a good penny... 6x6x8 rdwd for me is over $100 ea.
robertcdf is offline   Reply With Quote
Old 05-02-2007, 03:57 PM   #3
I had thought of going bigger but it wouldn't fit with the look of the yard. What about going with a different material all together? I have been thinking of using thick walled steel pipe and setting it into cement at least 3 feet down, but I don't know if that will solve the problem or not. I could also fill the tube with cement to provide extra support.
Patio cover Jackhammer Building & Construction 3 07-10-2007 03:49 PM
Patio cover lazyboykrebs Building & Construction 1 02-17-2007 04:07 PM
Patio Cover - Need help/suggestions DIYer Building & Construction 7 02-19-2006 09:00 PM
