Need Help With My Attic Trusses - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-23-2011, 12:49 AM   #1
need help with my attic trusses
there is some 2x4 i want to remove so i can intrude the wall so i can form this cave or crevice, but the 2x4 is in the way, just need to know can i remove it and would it have any stucture problem. There's a picture i hilighted the 2x4 that i want to remove.
MrHandy is offline   Reply With Quote
Old 03-23-2011, 01:22 AM   #2
Rewards Points: 1,016
Portion of an engineered truss, right? Leave it alone.
Old 03-23-2011, 05:57 AM   #3
DIY staff
Rewards Points: 7,174
Don't touch those-----what ever you do---don't cut those!
Old 03-23-2011, 06:30 AM   #4
What they said!!!!! Removing any member of an engineered truss severly compromises the whole truss.
Old 03-23-2011, 06:52 AM   #5
Rewards Points: 2,240
Sure, you can do it - we have.
However, we submitted "Detailed" drawings, with pictures to a Structural
Engineer.
After he examined our drawings and made a few suggestions/changes -
we re-drew the plan, re-submitted it, and then submitted the plans to the
"Local Code Enforcement" entity.
After everyone was happy (this took a while) - we went ahead and did it.
Sounds easy, doesn't it - it wasn't!
Take the advice from above -
Don't do it!!
rossfingal is offline   Reply With Quote
12-6 roof trusses, finish attic? chipraynor Building & Construction 0 03-10-2011 06:41 PM
capacity of 2x4 walls for new roof attic trusses Soccerfan8 Building & Construction 6 12-13-2010 05:09 PM
condensation stains from weathered 2x4 trusses in solarium attic space chris boland Building & Construction 3 06-11-2010 12:13 PM
Attic flooring on 2X4 trusses for light-medium storage Ehollenbaugh Building & Construction 12 02-01-2010 06:45 PM
I have a question on changing trusses, I am framing an attic room. wackerjr Building & Construction 17 01-22-2008 07:36 AM
