Need Help With Interior Wall Build - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-03-2011, 08:19 PM   #1
Need Help with interior wall build
Have a house where the front door opens up directly into the den, familyroom or whatever you want to call it. Anyway I am wanting to place a wall between the doorway and the den to create a small foyer. Since I will be just lifting it up, nailing in place and placing drywall on it, it sounds real simple. Is this as simple as I made it sound or is there more things I should be concern with. I know how to construct a wall and I will have to remove the bubble ceiling and carpet in the spot where the wall will be going up but is there anything else I should know before installing this interior wall? Thanks
bemgolf is offline   Reply With Quote
Old 12-03-2011, 08:32 PM   #2
DIY staff
Rewards Points: 7,174
That's called a 'partition' wall --and you summed it up pretty well---
One frequent difficulty occurs if the is nothing but drywall above to attach the top plate to--some walls run parallel to the joists and fall in between--
Often adding a trim or crown molding to the top saves you from messing up the ceiling while taping.
--Mike---
ben's plumbing (12-03-2011)
Old 12-03-2011, 08:43 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,334
mike is correct.
you can fasten directly to the finished ceiling with a combination of air spikes and construction adhesive if no blocking or strapping is present.. my only concern is regarding whether or not the stipled ceiling has a border where it terminates at the walls.. you will lose this effect unless your planning on refinishing the ceiling.. as for the carpet its shouldnt be too big a deal to go directly over it.. just be sure to remove the baseboard trim where the new wall joins so you can reinstall it with proper joints
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
How to build a romex spinner jimmy21 Electrical 17 02-06-2012 12:01 AM
time to build simple addition bmt1970 Building & Construction 9 03-05-2010 02:06 PM
Build or buy a shed and costs? Piedmont Building & Construction 7 05-19-2009 07:13 PM
To Build or Not To Build scoby1978 General DIY Discussions 6 05-27-2007 04:39 PM
