Need Help Installing Concrete Columns... - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-26-2011, 10:35 PM   #1
need help installing concrete columns...
any help would be appreciated what i have are 12' columns they are in sections and i think they are going to be epoxied together have never done this before so i need a little insight. TIA
z06bad is offline   Reply With Quote
Old 01-26-2011, 11:13 PM   #2
Rewards Points: 5,336
You think they will be epoxied together? Is this your project?
It might help(me) if you told us a little about the project.
Interior?
Exterior?
Weight of the columns?
Width of the columns?
Function of the columns?
Why epoxy and not mortar?
Region you live in?
Ron
Old 01-26-2011, 11:15 PM   #3
Scary
Is this a prefab product?
Did it come with instalation instructions?
ubenhad4 is offline   Reply With Quote
Old 01-26-2011, 11:48 PM   #4
Interior?
Exterior?
Region you live in?
Ron
ok my buddy asked me for help so I found this site and signed up to give it a try. A little direction might help.
there are both interior and exterior I said they would be mortared he said epoxy
8' to 12' tall non bearing they do come in pieces that are about 2' x 2'
central ca,
I relize i don't have all the info
Old 01-26-2011, 11:55 PM   #5
I have set plenty of one and two piece fiberglass columns but never pre fab concrete these are in a custom home.
just seems the price for install is very high.
Old 01-27-2011, 12:23 AM   #6
Probably a reason the install price is high. High risk of damage or future injury if improperly installed. Ive seen pros putting together pre fab concrete and stone mantles and columns and one little bump and a $1500 piece is toast.
Old 01-27-2011, 12:57 AM   #7
yes i did read about that earlier...he's got several of them to set and he has been qouted 35k for the install. I'm sure the manufacturer will provide instructions just hoping to hear from someone with experience.
Old 01-27-2011, 08:04 AM   #8
Rewards Points: 4,538
new 1 on me never even knew anyone supplied pre-cast conc columns,,, hopefully you've got a proper size crane to lift them into position,,, if they're cast properly ( square & plumb ) there needs to be a slight reservoir into which the epoxy can ' set ' w/o showing any ' drool ' down the sides of the columns.
what about the columns foundations ? solid or hollow columns ? reg or lite-weight conc ?
Old 01-27-2011, 01:19 PM   #9
central ca,
Why don't you get all the information and then come back.
Ron
Installing prefinished wood over concrete Beaver Handyman Flooring 13 01-03-2011 10:24 AM
Installing blinds.... Brackets need to go into concrete dtmbizzle Remodeling 5 05-05-2010 04:41 PM
Installing copper gutter to replace some concrete tiles whattodo Roofing/Siding 2 07-28-2009 08:28 AM
Installing a shower pan--questions on concrete floor RuthL Building & Construction 14 07-21-2009 01:16 PM
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 09:21 AM
