Need Help Framing A Long Partition Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-21-2013, 04:49 PM   #1
Need help framing a long partition wall
I'm about to try framing out a 30' partition wall in my shop. I'm not sure of the best way to do this. Can I build it in 3 10' sections, or do I need to do it as one big section (probably a stupid question, but I'm not sure.) It will have a door in the middle of it, so I will need to frame that out also if that makes a difference.
This is a non load bearing wall.
I appreciate all advice.
bkanneg is offline   Reply With Quote
Old 01-21-2013, 05:47 PM   #2
Rewards Points: 2,212
Is the ceiling already on?
Can frame as 30' then lift with the use of homemade walljacks.
3 10' sections is ok too. a 16 and 14 is good.
can also nail on top and bottom plates then put in oner stud at a time and toe nail.
mae-ling is offline   Reply With Quote
Old 01-21-2013, 05:59 PM   #3
Thanks! The ceiling isn't up. The tresses are exposed still. I'll probably have to go in sections since I have a short bed truck and can't fit long sections.
Just wanted to make sure that it was ok structurally.
Thanks again.
Old 01-21-2013, 06:40 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,334
if its not load bearing either stick frame it or frame it in short manageable sections
woodworkbykirk is online now   Reply With Quote
Old 01-21-2013, 08:43 PM   #5
DIY staff
Rewards Points: 7,174
Do the layout as if it were a continuous 30 foot wall--make the slpices in line with a stud---add an extra stud on the adjoining section.---when stood up---nail the two brother/sister studs together.
This will keep all stud spacing correct.
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
kwikfishron (01-21-2013), mae-ling (01-22-2013)
attaching a partition wall to an existing suspended ceiling cmonthenet Remodeling 14 04-06-2012 02:35 PM
Partition wall supporiting ceiling joists (recommendations for removal) afly007 Building & Construction 3 09-29-2011 10:57 AM
Removing spine wall beko Building & Construction 12 02-02-2010 01:15 AM
framing, expanding wall opening wall - load bearing? nave Remodeling 5 01-23-2008 03:44 PM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 04:23 PM
