Need Help Fixing Sill Plate / Rim Joist Due To Carpentar Ants / Water - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-26-2012, 03:51 PM   #1
Trucon01's Avatar
Rewards Points: 510
Need help fixing sill plate / rim joist due to carpentar ants / water
Hi All,
The pictures below are from the front of my town house. It looks like I had carpenter ants a while back plus a lot of water entry. How can I fix this?
Need help fixing sill plate / rim joist due to carpentar ants / water-photo-1.jpg   Need help fixing sill plate / rim joist due to carpentar ants / water-photo-2.jpg   Need help fixing sill plate / rim joist due to carpentar ants / water-photo-4.jpg   Need help fixing sill plate / rim joist due to carpentar ants / water-photo-5.jpg
Basement Demo started Jan 2012: View my basement progression!!!
Bathroom demo started Feb 2013: View my bathroom progression!!!
Trucon01 is offline   Reply With Quote
Old 05-26-2012, 04:22 PM   #2
kwikfishron's Avatar
Rewards Points: 356
Posting some pictures from the outside showing the entire area would be a good start.
kwikfishron is online now   Reply With Quote
Old 05-26-2012, 04:30 PM   #3
Rewards Points: 636
first of all my understanding of carpenter ants is they are after moisture so first figure out how wood is getting wet and fix that . as far as for the damaged wood. it is hard to say with out being there. i would start by taking a awl or pen knife and jab it into sill plate under floor joist and see if it is still solid and do the same for floor joists.making sure that there is at least 1 1/2 deep of good floor joist resting on sill plate. if they are solid. i would add a board between floor joist one on each side if damaged rim joist to keep joist from twisting but leave it out away from original around a foot so it can be checked for further issues.
then add a fastener to each side of rotted sill plate if not one within 2 feet a lift strap might be your only option if not enough room to get a drill in to drill through sill and into block
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 05-26-2012, 05:02 PM   #4
Trucon01's Avatar
Rewards Points: 510
Unfortunately, where the water is getting in, is right under the concrete stoop on the front door, no where else. From what I can see, the water is being sloped away from the stoop.
I'm currently outside digging next to the foundation, to get some pictures...
Old 05-26-2012, 05:12 PM   #5
Rewards Points: 356
Looking at your basement thread you have some major issues going on there.
I couldn't imagine going any further inside until all of your water intrusion issues are solved first.
Old 05-26-2012, 05:13 PM   #6
Rewards Points: 636
check rain spouts make sure they are diverting water away from pad. also can you post pic of outside what you see against house and stoop
Old 05-26-2012, 06:04 PM   #7
Trucon01's Avatar
Rewards Points: 510
As requested... I poured a bunch of water on both sides to see if I could find where its coming from and I see no water in the basement. Only when it rains heavily...
Need help fixing sill plate / rim joist due to carpentar ants / water-photo-2-1-.jpg   Need help fixing sill plate / rim joist due to carpentar ants / water-photo-1-1-.jpg   Need help fixing sill plate / rim joist due to carpentar ants / water-photo-1.jpg   Need help fixing sill plate / rim joist due to carpentar ants / water-photo-3.jpg   Need help fixing sill plate / rim joist due to carpentar ants / water-photo-3-1-.jpg
Old 05-26-2012, 06:09 PM   #8
Rewards Points: 636
see the dryer vent right of pic does that go through rim joist
Old 05-26-2012, 06:12 PM   #9
Trucon01's Avatar
Rewards Points: 510
Yes, but that is the vent from what used to be the bathroom ceiling fan. No water has been coming in on that side, just where the stoop is...
Do you want pictures of anything else, to help in any way?
Old 05-26-2012, 06:29 PM   #10
Rewards Points: 636
no the vent is a reference for height of rim joist. if it was me i would stop digging and concentrate on the door,door thresh hold, and stoop with sealing all cracks with a polyurethane sealant .like sika or quad brands at the box stores. they are not fun to work with thick and sticky but they will hold up and seal best to masonry products. also check grout for cracks that may be letting water in also
are there gutters and if so are they draining
The Following User Says Thank You to jaydevries For This Useful Post:
Ravenworks (05-27-2012)
Old 05-26-2012, 06:37 PM   #11
Trucon01's Avatar
Rewards Points: 510
Got it. I'll be outside filling the holes and checking what you mentioned!!! THANKS I'll let you know what I find.
Old 05-26-2012, 06:58 PM   #12
DIY staff
Rewards Points: 7,174
Run that hose under the door--on the top of the porch slab.
The rim joist is behind the brick face---on top of the foundation---
So it's likely that the water is coming from the door or behind the concrete porch--
Old 05-26-2012, 07:07 PM   #13
Trucon01's Avatar
Rewards Points: 510
Well well well. You guys found my problem..... Sum*****
Basement walls are now wet...
Need help fixing sill plate / rim joist due to carpentar ants / water-photo-1-1-.jpg   Need help fixing sill plate / rim joist due to carpentar ants / water-photo-1.jpg   Need help fixing sill plate / rim joist due to carpentar ants / water-photo-2-1-.jpg   Need help fixing sill plate / rim joist due to carpentar ants / water-photo-2.jpg   Need help fixing sill plate / rim joist due to carpentar ants / water-photo-3.jpg
Old 05-26-2012, 07:23 PM   #14
Rewards Points: 636
where old caulking has broke apart scrape off with painters tool or scraping knife if crack is over 3/8 wide use backer rod "foam rope" push into gap then seal with a polyurethane sealant
here is a good instruction link but i have never used there sealant
http://www.sashco.com/hi/caulking101.html
Old 05-26-2012, 07:31 PM   #15
DIY staff
That's not going to be an easy fix---
kwikfishron (05-26-2012)
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Water Leaking into Garage ghostee Building & Construction 2 06-11-2011 07:20 AM
Replacing Rotten Sill Plate Material Tester Carpentry 6 03-28-2011 08:08 PM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 11:32 AM
Sill plate and rim joist question bhasty Building & Construction 3 10-15-2009 02:07 PM
