Need Help With Fence Posts - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-29-2013, 04:28 PM   #1
Need help with fence posts
So just a quick back story to get you guys caught up to where I am right now. Two weeks ago my cousin and I started digging the holes for my fence posts. 10 inch diameter and 3 feet deep. I had rented an auger for the day $150. After 9 hours of fighting we got 4 holes dug out of 20. The whole neighborhood is built on top of shale rock. So for the price for me to rent the auger again for 2 more days and a jack hammer to brake up any rocks we run into. It was cheaper to hire a guy to come dig the holes for me. The only problem is he only has a 6 inch diameter auger bit. I was planning on filling the holes with concrete but now I am afraid that with the 4x4 post in the hole there wont be enough space around the post to have enough concrete to make it strong enough that it wont crack. So should I stick with concrete or just back fill the hole with dirt? I am really at a cross roads here.
handyman_squire is offline   Reply With Quote
Old 06-29-2013, 06:28 PM   #2
Rewards Points: 502
If your fence is only going to be 3ft high, you could probably get away with backfilling with dirt, at a pinch.
If it's 8ft high, no chance; wind load.
tony.g is offline   Reply With Quote
Old 06-29-2013, 07:01 PM   #3
no its 6 feet high going into the ground 3 feet.
Old 06-29-2013, 07:09 PM   #4
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Back fill will NOT work.
The fence will lean over time, sooner if you get high winds. Concrete is the was to go.
sublime2 is offline   Reply With Quote
Old 06-29-2013, 07:17 PM   #5
perfect thank you that is what I wanted to hear.
Old 07-02-2013, 12:26 AM   #6
Dave Sal's Avatar
Rewards Points: 600
I'd suggest considering adding metal post reinforcements to the 4x4's all the way to the bottom of the holes. If/when the posts snap (and one day they will), the metal will keep your fence from falling down.
Dave Sal is offline   Reply With Quote
Sinking Fence Posts cibula11 Landscaping & Lawn Care 16 07-25-2013 10:22 PM
Setting Fence Posts, Concrete or Not? Jim Ignatowski Landscaping & Lawn Care 11 01-19-2013 11:27 PM
6' wood privacy fence questions snosurfa7 Landscaping & Lawn Care 13 06-01-2012 02:45 AM
Replacing fence posts in concrete lostwithoutamap Landscaping & Lawn Care 2 04-24-2012 03:31 PM
Posts in a chain link fence.....cemented down yummy mummy Landscaping & Lawn Care 0 07-14-2008 10:54 AM
