Need Help Enclosing A Deck. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-06-2006, 01:36 PM   #1
Need help enclosing a deck.
Okay, here goes, i need some ideas. I just bought a house and on the back is a 2 level deck. The entrance to the back of the house is sliding window doors that are on the upper level of the deck. I would really like to enclose the uppder level of the deck. I dont know if i want to make it a window/screen type enclosure, or just screen. My main question is how to deal with the roof. I am really on limited funds and would like to try and build it from scratch, but kits would work as well if the price is right. Any suggestions welcome!!!
thanks,
Dave
dirtyb115 is offline   Reply With Quote
Old 06-06-2006, 02:49 PM   #2
Construction Estimator
The roof is a toughy! The main problem is to tie into your existing roof line or do something more...oh how shall we say..flimsy! You also have the added weight bearing problem on the supports for your deck. The age of the deck is also a concern. Wood decks only have a limited life span. This is something that if you are going to do yourself and want it done right, you might consult some local tallent I.E. friends and family. Something like this is best if seen. Posting some pictures of the situation would help for advise gathering here.
DaveH is offline   Reply With Quote
Old 06-07-2006, 12:12 PM   #3
Thanks for the reply. I move in in about a week so ill post some pics sometime the week after.
Dave
Old 06-11-2006, 12:20 AM   #4
Carpenter
DecksEtc's Avatar
You may be setting yourself up for a lot more work and cost than you expect. Putting a permanent roof up requires a permit and a structure that can support the roof, snow loads etc.
An alternative option for you would be the metal framed gazebo/screen rooms that you can set up and take down as needed. There are lots that have the screen removable should you want that option.
Terry
DECKS Etc.
GardenStructure.com
DecksEtc is offline   Reply With Quote
deck - beam to post connection (??) brocasArea001 Carpentry 21 05-11-2011 09:39 PM
What size deck is 'good' for our situation? curls00 Carpentry 20 09-08-2007 08:12 PM
deck questions robphelan Carpentry 6 06-25-2006 07:42 PM
Subfloor question for new deck and solarium CM2U Building & Construction 3 07-27-2005 10:50 PM
deck walls maintenance Building & Construction 6 04-03-2005 11:37 PM
