NEED HELP - Drywall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-11-2008, 11:33 AM   #1
NEED HELP - Drywall
Ok so hello guys im in a big mess right now. I am doing my first drywall job ever. I had to cut a trim in a room that was about 3 feet from the top of the room all around.
I did my taping and the next day I put the mud in like this
Now unfortunately I thought that you left it like that and then come back to sand it. Mine is about twice as thick as that , It is now day 7 and I am going to see if it is all dry so I can just sand it.
Any suggestions? Will sanding it make it look nice n flush or will I have to tape again?
fresco is offline   Reply With Quote
Old 01-11-2008, 01:57 PM   #2
Yikes, you put the mud on WAY too thick. Ideally what you want to do is put on 3-4 coats paper thin, and then feather each edge out a little wider than the last so that it smoothly blends the differences out so you can't really see them.
If your mud is dry, I'd first attack it with a metal drywall knife, probably 6" across, and see if you can knock some of the really thick stuff off. After that you'll probably have to sand it and see how it looks. You may end up needed to apply some more mud to feather it though.
Do a google search for drywall taping and there will be tons of links.
Eric
perpetual98 is offline   Reply With Quote
Old 01-11-2008, 02:07 PM   #3
Building and plumbing
USP45's Avatar
Rewards Points: 150
taping is a long drawn out practice makes perfect. There are a lot of tricks that pros use to simplify things. Usually when you tape you place mud on the seam, lay in the tape, push the tape firmly into the mud with a blade smushing out the excess, then recoat using a wider that the tape blade and get somewhat smooth. Then let dry, sand off the humps, not smooth, just knock down the humps. Then using a 10 to16 inch wide blade start to place mud on both sides of the joint. let dry. Again do not sand down, just sand off the high spots, repeat again and this tome sand so as to feather the edges in. Done. What you appear to have may be able to be sanded. I dont know how much mud is over the tape. If you see that you hit tape while sanding STOP and apply more mud.
USP45 is offline   Reply With Quote
Old 01-11-2008, 02:08 PM   #4
USP45's Avatar
Rewards Points: 150
Another trick to hiding bad taping is to paint with a flat paint as high gloss acts like a mirror exposing all the flaws
Old 01-11-2008, 02:18 PM   #5
yummy mummy's Avatar
Rewards Points: 1,016
If all else fails, a nice textured wall would look great.
Just kidding. I'm certain that you can get it to look good. Here is a website that has great information on taping for beginners.
www.drywallinfo.com
They have really good instructions. Also, www.drywallschool.com is another good one with videos. Unfortunately, you didn't look into it first, but not to worry, it will look great. Just some patience and practice.
yummy mummy is offline   Reply With Quote
Old 01-11-2008, 03:48 PM   #6
If you want to remove lots of mud, just get a drywall rasp. It will cut through that in no time, and then you can try again. WAY faster than sanding, and less mess.
jdelisle is offline   Reply With Quote
Old 01-11-2008, 05:59 PM   #7
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
YIKES!....ever consider a stucco-type finish, instead of smooth?
- Build Well -
Old 01-11-2008, 08:26 PM   #8
You can file your nails as you walk near it.
Old 01-12-2008, 07:06 AM   #9
I would suggest you find a small area that is not very noticable and practice a bit before trying this again.Without a rasp or a small sander you will be forever trying to get that down to a workable surface
clasact is offline   Reply With Quote
Old 01-12-2008, 07:55 AM   #10
Belt sander? Just kidding. Most of the ridges should knock down with a drywall knife and sanding screens should take care of the rest.
jerryh3 is offline   Reply With Quote
Replacing 12" ceiling tile with drywall housefixin Remodeling 5 09-09-2007 03:00 PM
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 08:52 AM
Celing Drywall and Hurricane Clips Ricky D Building & Construction 2 04-09-2007 05:59 PM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 05:47 AM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 07:11 AM
