Need Help With Choosing The Right I-Beams - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-08-2011, 06:00 PM   #16
ddawg16 ... thank you so much for your info ... I did some research about PSL beam and found the following great resource with sizing tables ... http://www.ilevel.com/literature/TJ-9000.pdf ... check pages 14/15 ... it's exactly what I was looking for ... I will just skip the I-beams and go with PSL beams ... thanks again for the hint.
luckyluke is offline   Reply With Quote
Old 11-08-2011, 06:02 PM   #17
Framing Contractor
Rewards Points: 118
What size did you determine that you needed?
sixeightten is offline   Reply With Quote
Pergola Notched Cross Beams Are Bending and Warping dcunited122 Building & Construction 10 06-25-2012 06:20 AM
Connecting Beams And Post JoeLena Building & Construction 5 01-01-2011 04:32 PM
Wiring on exposed wood beams - Ontario Canada djgap Electrical 5 09-29-2010 12:41 PM
Deck project - Shim beams or joists? jcims Carpentry 1 08-08-2009 08:02 PM
hanging weight off of tji beams?? summer76 Building & Construction 2 04-14-2009 02:00 AM
