Need Help Calculating The Length For A Cut - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-05-2013, 11:18 AM   #1
Need help calculating the length for a cut
Not sure if I'm just slow today or what, but I can't figure this out. Building a work bench onto a wall using 2x4s. Bench comes 21" from the wall and I'm trying to make the angle cuts to go from the outside 2x4 to the wall (basically a triangle). Can anyone tell me how to figure this?
rkwerchan is offline   Reply With Quote
Old 02-05-2013, 11:31 AM   #2
Rewards Points: 674
A squared plus B squared equals C squared according to Mr Pythagorus.
Not sure how far down you want it to go on the wall.
B
Beepster is offline   Reply With Quote
Old 02-05-2013, 11:33 AM   #3
"You can do anything"-Mom
brockmiera's Avatar
Pythagorean theorem
(a^2) * (b^2) = c^2
If both legs are 21" then its
441" + 441" = c^2
882" = c^2
c = 29.7"
brockmiera is offline   Reply With Quote
Old 02-05-2013, 11:40 AM   #4
brockmiera's Avatar
Also if you make both legs the same say 16" and 16" then you have essentially the diagonal of a square.
Length of brace would be length of leg times the square root of 2.
Your cuts are easier if the legs are the same. 45 degrees each.
Old 02-05-2013, 12:34 PM   #5
Got it at 30"! Thanks guys! My geometry really stinks!
Old 02-05-2013, 12:40 PM   #6
brockmiera's Avatar
No problem. Looks like you are off to a great start. Post some progress and finish pics. I'm sure everyone here would like to see it finished!
Old 02-05-2013, 02:57 PM   #7
This was just a quickie. Just got divorced and the wife got the house with the big garage and my big workbench. Just needed a place to work on my guns so I threw this together. Also used it as an excuse to buy a new miter saw then realized I have no place to keep it...
Thanks again for the help!
LED strip length? Karpiel73 Electrical 4 04-29-2012 09:46 PM
AC Temp drop over plenum run length BlueBSH HVAC 23 06-22-2010 08:10 AM
Max span length on 4-2x10 fir beam? gadget463 Building & Construction 4 08-03-2009 05:51 PM
Hardwood Length...preference? JDeFuria Flooring 3 03-10-2009 05:38 PM
total effective length question drewhart HVAC 2 01-27-2009 08:46 PM
