Old 10-24-2006, 04:53 PM   #1
Default Need help with basement support
Hello everyone, and thank you in advance for any help or advice you can share. We moved into our house 5 years ago and it is an old home. The original structure was a log cabin built in 1841 and has been added on to and improved thru the years. We got it at auction and knew going in that the house was ancient and the floors are all uneven. The basement is only a half basement : roughly 30' x 30' . It is very well built though, with 2' thick huge sandstone block walls, and 12" x 12" hand hewn support beams for the first floor and walls. In the very center of my basement is a single 10" x 10" oak support post that is supporting the criss crossed support beams and basically the rest of that part of the house. For peace of mind i want to add additional support posts , but need to know how deep to go down and what is the best procedure to pouring for a footer to put these posts on? Is it something a home owner can tackle or am I in over my head? I am fairly handy , as i have done most of the repair and improvements to the home, but have never delved into pouring footers. Thanks again for any advice......James
jaw522 is offline   Reply With Quote
Old 10-24-2006, 08:34 PM   #2
renovations
Jaw, what is the existing 8x8 post sitting on? Is it moving? If there's no movement, why mess with it? It's been there for 165 years already. Having done hewing I'd love to see some pics if you have them, Rich.
Bonus is offline   Reply With Quote
Old 10-25-2006, 07:46 AM   #3
General Contractor
joasis's Avatar
As Bonus said, why mess with it if there isn't a problem? Unless you can actually detect settling or cracks indicating something going down, I would not advise just installing lally columns for a feel good feeling. If you actually need to add support, the size of a footer (pier) is determined by load and soil type and compaction. This could be a DIY project, but you need local advice from an eperience contractor or building inspector.
joasis is offline   Reply With Quote
Old 10-25-2006, 10:55 AM   #4
Remodeling Contractor
wolffhomerepair's Avatar
I have to agree if the beam is not sagging leave it. The uneven floors may be due to foundation shift also. Something to think about before you add columns for no reason.
http://www.wolffhomerepair.com
wolffhomerepair is offline   Reply With Quote
More On This Topic
Tools For Building Pergola
Tools For Building Pergola by Expert Village
Okay, this is Bob Street with Houdini Home Improvements on behalf of Expert Village. We are here in Mason, Ohio today and we are going to build a trellis. We've come onto the job site and the concrete fellows had been here before us. They've already... Read More »
If moving walls is in your plan, there are several things to consider. You want to consider what is in the wall. Is there electric in the wall? Is there plumbing in the wall? Where is it? Where can you move it? Can you take it out? What would be the... Read More »
Hi I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. When you're framing your basement by yourself, or if you've hired someone else to do it, one thing to think about is the spacing that you will use to space... Read More »
Hi this is Drew Finn for expertvillage.com we are going to talk about cleaning and maintaining a deck. This video is presented by Black Dog Video and you can visit us on the web on blackdogvideo.biz. When we are checking underneath we want to make sure... Read More »
Okay this is Bob Street with Houdini Home Improvements on behalf of Expert Village. In this clip I will be showing you how to cut the scroll on the beam. First you make all of your straight cuts using a circular saw. Next you will finish those cuts with... Read More »
Sub Basement Walkout - Please Help pgs_28 Building & Construction 11 08-12-2007 11:55 PM
IRC 404 Basement walls lateral support? bjr23 Building & Construction 2 07-26-2007 11:07 AM
Basement - Removing or moving support post jfgagnon Remodeling 9 05-06-2007 02:36 PM
Need advice on bending support post in basement SalukiFan Flooring 0 03-21-2007 11:39 AM
Temporary support for replacement of basement beam Mikedks Remodeling 8 09-14-2006 08:36 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
