Need Help With Bad Beam - Building & Construction - Page 3 - DIY Chatroom Home Improvement Forum
Old 07-11-2012, 12:06 AM   #31
AHH, SPANS!!!
Rewards Points: 1,166
Originally Posted by LVDIY View Post
CooperClad: Yes, 4x4 runs from bottom plate to top plate. The bracket is nailed to the 4x4, and I assume there are some nails driven up through the bracket into the beam. That bottom wrap board was still in place last time I looked at it, so I only got a clear view of the bracket from the side. The beam is resting on nothing else but this bracket.
So to do this properly I would have to remove and cut down the 4x4 in order to create proper support?
hand drive: Maybe it's getting late, but raise the ceiling to make it level with what? I get the part about supporting the ceiling while replacing the beam, but I'm still not sure why I would raise the ceiling? Sorry if I'm not getting this...
No problem. maybe the most important reason for making the ceiling level is so the new beam rests against the ceiling joists evenly across the entirety of the beam from end to end.plus, a level ceiling looks good
If you sight along the beam now you will see a dip in the middle, the ceiling joists are following this dip as well and you want to raise the dip. it is best to deal with the dip before putting the temporary wall in and then the wall holds it all level while you rework the beam.
hand drive is offline   Reply With Quote
Old 07-11-2012, 12:27 AM   #32
Rewards Points: 149
CopperClad: that sounds like a plan. Thanks for all your help so far, I'll probably be back with more questions once I start this process.
hand drive: now I do get what you mean. I thought you were talking about raising the whole ceiling. Yeah the ceiling is a little wavy, rather than just a dip in center. The walls that the joists rest on are also out of level, so I doubt I can get it perfect, but if I can correct some of it, that's probably worth it. With that said though, I have yet to find anything being level in this building.
LVDIY is offline   Reply With Quote
Old 07-11-2012, 09:07 AM   #33
AHH, SPANS!!!
really, making it level is mostly so the new beam fits into the space correctly. once you put the beam in, the ceiling will really have no choice but to follow the level beam so it is easier to work the level ceiling out ahead of time.
The Following User Says Thank You to hand drive For This Useful Post:
LVDIY (07-11-2012)
Old 07-11-2012, 09:28 AM   #34
Rewards Points: 149
Got it! That makes sense to me now!
Old 07-11-2012, 06:28 PM   #35
Rewards Points: 149
Originally Posted by CopperClad View Post
And even though the 4x10 is overkill I would just put the same thing back up to minimize any extra work.
This is probably what I'll do, but just out of curiosity, what size beam would be normal for this type of span?
Old 07-11-2012, 06:34 PM   #36
Normally there would be no beam for a room that size.
CopperClad is offline   Reply With Quote
The Following 2 Users Say Thank You to CopperClad For This Useful Post:
Evstarr (07-12-2012), oh'mike (07-11-2012)
Old 07-11-2012, 08:47 PM   #37
AHH, SPANS!!!
except if the joists have a break in them mid span..
Old 07-11-2012, 08:57 PM   #38
The span is 13' . A 2x6 can span that for a ceiling with no problem. So normally, there would be no beam.
Old 07-11-2012, 09:07 PM   #39
Rewards Points: 149
I get that under normal conditions there would be no need for it, but since my joists do overlap, I was just curious what size beam would be sufficient if a 4x10 is overkill.
Actually, I just checked the beam, and I guess those wrap boards tricked me when I judged the size. Turns out it's a 4x8, not a 4x10.
Another random thought I had: would it somehow be possible to bolt the overlapping joists together and let then span the full 13ft and just remove the beam altogether?
Old 07-11-2012, 09:37 PM   #40
DIY staff
Rewards Points: 7,174
A lapped and bolted joist will sag---sorry---
LVDIY (07-11-2012)
Old 07-11-2012, 09:43 PM   #41
LVDIY. Is cost your concern? Or after thinking about it would you prefer a flat ceiling with no exposed beam?
Old 07-11-2012, 09:46 PM   #42
Rewards Points: 149
OK, that makes sense!
Old 07-11-2012, 09:55 PM   #43
DIY staff
You are back to the original three choices---saddle beam above--exposed beam below or replace with full span joists---
None are that difficult---just a matter of time and cost----
Old 07-11-2012, 10:03 PM   #44
Rewards Points: 149
No, I wasn't thinking of cost, and I actually like the exposed beam. I just like running through different options when faced with a task in order to pick the best one, rather than just doing what seems obvious at first. It's how I tend to approach other things. I'm a DIY newbie, so sorry if I ask a lot about a stuff that might seem obvious to you guys.
My plan is still to replace the beam.
Old 07-11-2012, 10:12 PM   #45
Want some more options? Let's due away with the beam and the ceiling joists altogether. Attach 4x4'sfrom rafter to rafter every 16'', about 3' down from your ridge, and you can have a bomb diggity cathedral sheetrocked ceiling with exposed collar ties in your office . No need to apologize LVDIY, nothing wrong with going over your options before hand. A lot of the people on here post after they have screwed up and ask how to fix it. You didn't screw up, ya just didn't know you had a colony of ants you should have been charging rent.
drilling through steel I beam DIYguy2000 Building & Construction 3 11-21-2011 09:39 AM
How to repair main support beam Jerry48ece Building & Construction 0 01-08-2011 09:38 PM
Main Beam De-Laminating Bird Doo Head Building & Construction 6 12-09-2010 01:08 PM
Crawl Space Beam and Joist Support Questions Fire4Effect Building & Construction 5 06-28-2009 02:07 PM
Beam Replacement? Steve Dailey Carpentry 5 05-19-2008 09:46 PM
