Need A Guesstimate - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-10-2011, 02:15 PM   #1
TheBrewNinja's Avatar
Cool
Need a guesstimate
I just purchased 2.5 acres of land in CA just north of Edwards AFB and want to build my own home; I already have the plans in hand which will be changed some what.
The blue prints call's for a crawl space and I want a full basement.
It is a two story home with garage on slab. The homes deminsions are approx 65' x 20' and I want a basement with 7 foot ceiling as I will be adding a wine cellar and in home winery in the basement; so it will need to be waterproofed and insulated.
The home will be totally off the grid solar/wind power, well water & septic tank. I will want the septic & leach fields dug at the same time as the basement and foundation.
What I am looking for is a rough guesstimate of what I am looking at the the dig and prep?
Here is an artists rendention of what the house will look like...
Thanks guys!
TheBrewNinja is offline   Reply With Quote
Old 03-10-2011, 02:30 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
You mean like a cost estimate? If so, I suggest you contact a few excavation companies in your area. If this was my project, the cost to excavate would be whatever diesel fuel used for the equipment for after all this is a DIY site.
btw: I know guys that charge $75/hour for an excavator and I know guys that charge $200/hour. What somebody charges you is going to be very location and even contractor specific. That is why you need to get a bid or estimate locally.
I like the look of the house though. Got a place I could go and look at the layout of the house? Not sure about the "20'" wide but it might be workable if the layout is good.
edit: I would suggest at least an 8' basement. Once you consider any supporting steel (if applicable) you lose a foot for that. If you want to put a drop ceiling in, I would use the 8' even if there is no steel
Old 03-10-2011, 02:52 PM   #3
NAP;
I'm debating on wiether I want to dig myslef or hire someone to do it but I want to make sure the foundation is done right but the actual construction of the home I plan on doing myself, everything from framing, electrical, plumbing and finish work. I just want to make sure its not going to come down at the first breeze!
The house is a total of 2032 sq feet on an open floor plan with the master bed / bath and an office/den on the upper floor and a roof top patio, the main floor has the guest bedroom, bathroom, kitchen, dining and living area.
The lot is 2.5 acres in the desert I can send you the blue prints in .pdf form if youd like to check them out? Just shoot me an email TheBrewNinja@gmail.com
I see your in SW MI! I'm in Detroit-Murderous myself. I'm looking to sell my three homes here to move to Cali and buil a new home!
Old 03-10-2011, 04:57 PM   #4
nap
You talking to me?
nap's Avatar
Motor city? Ha!!
If you hang around long enough, it sounds like most people will move from inner urban to suburban, or even rural with never having moved. I see pictures of Detroit that are saddening. Some really grand old buildings simply gone and discarded.
there are a couple guys that post here that might be able to give yuo some reasonable estimate of time which can be converted to $$ with simple math. I'll have to contact you on the plans.
Old 03-10-2011, 05:20 PM   #5
Experienced
Jackofall1's Avatar
Basement in California, do you have a blasting permit?
You know it shakes there don't you?
Mark
Old 03-10-2011, 05:27 PM   #6
Mark
Good then I wont have to do as many punch downs on my fermenting wines!
Out in the desert I'm hoping it wont be to rocky when I dig if not I'll find a way to get it dug! I can male my own eh' "digging devise" out of simple items!
Old 03-10-2011, 08:31 PM   #7
Rewards Points: 150
The house is nice, but how's your building experience? sometimes it takes blood and guts to see these jobs through.
bernieb is offline   Reply With Quote
Old 03-10-2011, 10:17 PM   #8
I worked for a while as a carpenter; studies house wiring and plumbing for a while and I use to work as a property manager and had to do a lot of repair works in apartments, homes and even a cinema.
i know it will be time consuming, back breaking and teadeaus but you cant truly say something is your if you didnt build it yourself!
