Need To Get 70LB Weight From Ground Into SUV - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-16-2011, 02:14 PM   #1
Need to Get 70LB weight from ground Into SUV
Any ideas how i get a 70 LB weight from the ground in and and out of my SUV? After 2 surgeries cannot lift it so need help. Any ideas much appreciated. Thanks.
Chris
nomad2012 is offline   Reply With Quote
Old 08-16-2011, 02:22 PM   #2
Learning by Doing
Leah Frances's Avatar
Ask your neighbor/church volunteer/community organization.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 08-16-2011, 02:32 PM   #3
Code05's Avatar
Rewards Points: 1,104
Cheapest way I know of if you can not get help.
Code05 is offline   Reply With Quote
Old 08-16-2011, 02:36 PM   #4
Leah - I'll be in the desert so no one around.
Old 08-16-2011, 02:37 PM   #5
Code - thanks for the reply - but what is that ?
Old 08-16-2011, 02:40 PM   #6
Code05's Avatar
Block and tackle, you can lift heavy weights with little effort.
Old 08-16-2011, 02:42 PM   #7
If you have a jack you could try to put the weight on the jack and try to slide the weight into your suv it might work
Mufasa02 is offline   Reply With Quote
Old 08-16-2011, 02:44 PM   #8
Learning by Doing
One of those ramps for atvs or dogs and slide/roll it out.
Break it into component parts. My Grandmama buys 50lb bags of mulch. She gets the hardware place to put them in the trunk. Then she takes it out 5 lbs at a time.
Old 08-16-2011, 02:44 PM   #9
Love the idea - thanks. But in the desert just need something to hang it on...hmmmm.
Old 08-16-2011, 02:46 PM   #10
Leah I have one 55lb generator and 1 70lb battery so cannot be broken into partrs - sorry I should have specified.
Old 08-16-2011, 02:58 PM   #11
Code05's Avatar
Is something like this an option? I do not have a clue about the weight limitations.
Old 08-16-2011, 03:05 PM   #12
Rewards Points: 6,652
We have a heavier duty one of those Code05. I have placed a rear tine tiller & front tine style tiller on it, with no problems. As for the OP, I would get a couple of neighborhood kids, or a neighbor to help. I send my boy who is 15 next door, when ever the neighbor needs something moved over at her house.
Old 08-16-2011, 03:50 PM   #13
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
Weight limitations on these carriers is mostly determined by tongue weight. If you have a 2" hitch, you should be good for 500lbs
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 08-16-2011, 03:53 PM   #14
Rewards Points: 5,336
If it's a body, just drop it off the back of the truck near the hole.
Okay, I see, it's on the ground already and you want to lift it up. How about a seesaw on wheels.
Take a 2x10 and put it on top of saw horse. Roll the item on the inclined wood and sit on the other side. Then just edge it onto the truck back and roll it off.
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
gregzoll (08-16-2011)
Old 08-16-2011, 03:57 PM   #15
Learning by Doing
Ground rod and ground wire question mulltron Electrical 17 07-29-2011 06:10 PM
How to connect ground wires? Iva Electrical 3 10-29-2010 01:13 PM
To ground or not to ground Red Squirrel Electrical 2 10-14-2010 09:42 PM
Wiring an outlet using both ground screws instead of pig-tailing together. cabber24 Electrical 5 08-26-2010 09:40 AM
Electrical Ground Problem cabinetman Electrical 15 01-28-2010 05:55 PM
