Old 01-13-2010, 06:00 PM   #1
Learning by Doing
Leah Frances's Avatar
Need to fix old plaster on brick wall - any hints?
How best to repair 200 year old plaster on brick walls. I am preparing for my next phase of my Library renovation. Demolition is complete!
As the pict shows I have bare brick (exterior wall), intact scratch, intact brown, and intact hard coat. In the end, I want a consistent attractive surface. I am willing to take the time to do this right. I have done veneer plaster in other parts of the house and have gained good results!
I also have one major, but stable crack that needs repair:
I would love to hear any ideas, tips, advice, cautionary tales, etc about doing this right.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 01-14-2010, 06:55 AM   #2
Do it the way it was done way back when, with 3 coat system. But you won't be using horsehair in mix as a binder. The brick should be rough enough to hold the 1st coat.
Venetian Plaster FYI Plaster Ayn Painting 10 07-01-2010 12:26 AM
Question regarding adding a stud wall to a brick structure jcieutat Building & Construction 0 12-15-2009 08:41 PM
Exterior Brick Wall with No Sheathing? beesan Building & Construction 1 12-08-2009 06:57 AM
how to make white mortar for brick wall nhertel Building & Construction 2 05-26-2009 09:22 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
