Need To Fill A Small Crack In Foundation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-26-2011, 07:15 PM   #1
Rewards Points: 16
Need to fill a small crack in foundation
So... this is where the waste pipe in my basement goes through the foundation to the outside world:
When it rains very hard I get some water in the basement coming from this corner. Not a lot, but enough to make the floor wet and annoy my wife when she goes down there. I had a good look at it today and realized that it looks like when the pipe was installed, they cemented all around it except for one small area, and there's a hole in that area:
There's stains on the wall where the water has been leaking so I'm positive that this is where the water is coming from. Outside I've done some work to keep the water away from the foundation, but I still need to fix this hole. Is this something I can do myself with some product I can get at the local Home Depot or Lowes? Or would I need a pro to take care of it?
mikelbeck is offline   Reply With Quote
Old 11-27-2011, 07:50 AM   #2
Rewards Points: 5,336
Hydraulic cement will work. Better if you can apply it from both sides, but the interior will do. You'll need to drill out a wider opening, making sure the walls are parallel to one another. The deeper the better, but at least an inch.
If the grading outside is good and no water collects near the foundation, the solution should last for up to 7-8 years.
Ron
B. Franklin 1759
Old 11-28-2011, 07:22 AM   #3
Rewards Points: 16
How much wider do I need to drill it out?
Old 11-28-2011, 08:09 AM   #4
I'd make it at least 1/2" at a 1" depth. The walls need to be parallel for the force of the expanding cement to work.
Ron
B. Franklin 1759
Old 11-28-2011, 08:26 AM   #5
Rewards Points: 16
Got it, thanks!
Cinderblock Foundation Crack.. Pictures! Shawnzy Building & Construction 10 10-29-2011 11:10 AM
How to seal a leaking foundation crack from the home's exterior brokenhammer Building & Construction 5 01-02-2011 09:08 AM
Fill hole in foundation wall after Gas line was removed ctbfalcon Building & Construction 2 05-03-2010 08:16 AM
foundation crack -- uncovering footing AFTER interior drain tile put in? downers Building & Construction 6 05-18-2009 12:07 PM
Stone foundation for a small shack andrgo Building & Construction 10 09-13-2007 01:49 PM
