Need To Fill Nail Holes In Drywall, What To Use? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-12-2008, 08:30 PM   #1
Rewards Points: 150
Need to fill nail holes in drywall, what to use?
I need to fill many little nail holes in the drywall in my house before priming. There are also some larger screw holes that I would like to fill. What is the eaisest way to do this and have it come out nice. Thanks.
twilightcall is offline   Reply With Quote
Old 05-12-2008, 08:33 PM   #2
remodeling pro
The small nail holes can easily be filled with lightweight spacking. You should be able to use it on the screw holes also, but they may require a touch with some fine sand paper. BY "small" nail holes, I assume you are talking about old holes from picture hanging and such, not from drywall installation.
troubleseeker is offline   Reply With Quote
Old 05-12-2008, 08:49 PM   #3
Rewards Points: 150
Exactly. They are very thin from small pictures on the wall. The screw holes are a little larger but not very large. Do you sand it with 600 grit sand paper or is that too smooth?
Old 05-12-2008, 09:20 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Use a non-shrink spackle.
Coat at least 2 X.
If the paper surface of the drywall is "pronounced" (above the wall surface)...First - bang it or "push" it flat or indent it.
Then spackle it over.
When relatively smooth, sand with a 100 to 120 grit sandpaper. Sand lightly.
Prime the area, and paint.
- Build Well -
small holes in drywall mud kimmyb General DIY Discussions 5 01-26-2008 10:21 AM
Gaps in drywall. What to use to fill them in. yummy mummy Building & Construction 13 01-02-2008 01:19 PM
Color problem with filled nail holes alternety Painting 3 11-05-2007 12:16 AM
Temporary nail to hold drywall; what to do with it? yummy mummy Building & Construction 47 10-19-2007 10:34 PM
Filling nail holes on paint grade trim? Yeti Carpentry 3 10-07-2007 10:53 PM
