-   -   Need to expand existing concrete pad for A/C unit (http://www.diychatroom.com/f19/need-expand-existing-concrete-pad-c-unit-759/)
miketegra 06-29-2005 07:49 PM
I have a concrete pad upon which sits my current outdoor air conditioning compressor.
I am putting in a new unit which is physically larger than the current unit. The current unit sits upon a 30" x 30" pad, about 7" thick. This pad sits on another pad right next to the house that incorporates a planter box and a brick box around a basement window.
The new pad needs to be about 46" x 34"
My plan is to:
1. build a form of the appropriate dimensions around the existing pad
2. clean and then apply a concrete bonding adhesive to vertical edges of the existing pad
3. run some long (6"-8") bolts about halfway into the vertical edges of the existing pad. The idea is the half of the bolt sticking out will provide an anchor to hold the new concrete to the old concrete
4. fill the form with new concrete, finish it, etc.
The existing pad cannot be demo'd since the current A/C unit is on it, and this unit needs to stay there right until the new one is seconds from being installed. So I plan to only add concrete around the edges to make it larger, and do not plan to add any concrete over the top. I know this plan will create a seam where the new and old concrete meet. Since I am adding on such a small amount of concrete, it doesnt seem like using a fiber expansion joint is necessary.
Any thoughts, ideas, or critisicm of this plan are greatly appreciated.
FYI I am a carpenter, but work along with a general contractor so I am familiar with, and have some experience pouring concrete pads.
Mike
plumguy 06-29-2005 09:11 PM
My plan is to:
Mike
Sounds good I like the idea of the bolts. Where you are a carpenter you might want to join their other site Contractor Talk you would get a lot more responses to you're posts.
Teetorbilt 07-03-2005 11:27 PM
Use lead anchors and stainless steel lag bolts and everything should be OK. I don't like using impact drills in this application because they can cause surface fractures that can show up years later. Sounds like you have a solid plan.
