Need To Cut Thru Ceramic Tile In Utility Rooom? Any Advice - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-22-2009, 11:50 PM   #1
Need to cut thru ceramic tile in utility rooom? any advice
I'm going to cut a whole in the floor for a new dryer vent and the room has ceramic tile in it and then backer board and then OSB> any suggestions on how to cut thru tile without cracking it?
kw151002 is offline   Reply With Quote
Old 06-23-2009, 07:05 AM   #2
Use a 4" grinder with a tile cutting or diamond blade, cuts it like butter.
Old 06-23-2009, 07:24 AM   #3
JB has it right, but just be sure there is no in floor heating, electric or hot water.
Cut your pattern , ocatgon will work nicely, a bit oversize say 1/2" to allow seating of your pipe. Put a wide pry bar under the edge and the tile will pop. You may have to make an x under the tile layer as you proceed down.
Chemist1961 is offline   Reply With Quote
Ceramic tile over existing (full mud) ceramic? rjniles Flooring 7 12-24-2008 07:12 PM
Need Pro Ceramic Tile Advice Sasha2000 Building & Construction 7 10-10-2008 07:49 PM
Question on preparing surface for Ceramic Tile Rferret Flooring 3 07-20-2008 01:08 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
need contractor advice for laying kitchen tile ng622 Flooring 5 12-07-2005 11:28 AM
