Need Concrete Recipe - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-08-2009, 07:13 PM   #1
If I needed to cover an area of 30 square feet at 2 inches thick using 1-2-3 formula of cement, sand and gravel, how much of each would I need? Cubic units always confuse me so if you could provide both the weight and volume measurements that'd be great, thanks.
applebuilder is offline   Reply With Quote
Old 07-08-2009, 07:49 PM   #2
9 - 80 pound bags of the pre-mix but 2" is a little thin. Whats it for?
oh yeah, its one part Portland cement, two parts sand and three parts coarse aggregate.
II Weeks is offline   Reply With Quote
Old 07-08-2009, 09:27 PM   #3
I'm making pavers for a garden path. 1 part cement, 2 parts sand and 3 parts aggregate was actually what I meant by "1-2-3 formula." Would you happen to know the weight and volume value of all the dry materials? I might go with a concrete pre-mix like you suggested but I wanted to see if I could save some money mixing my own.
Old 07-08-2009, 09:37 PM   #4
just a quess
but its 360 pounds gravel
240 pounds sand
120 pounds portland
like I said, just guessing buts 1-2-3
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 06:25 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 08:21 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 01:32 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 10:27 PM
