Old 12-29-2006, 01:00 PM   #1
Default Need to Cement Up old Basement Doorway
Hello to all, I'm new here,..............looking for some insight on walling-up a basement doorway that I feel should of never been installed. The prior owner put the basement door in to make easier access to the basement but there is a creek about 50 feet away and if that creek overflows there's only about 2 feet of possible rise before the water comes through the pathway to that door. Needless to say, this worries me alittle, with the doorway walled back up, water would have to rise an additional 7 feet to reach the first floor.
The door & frame is easy enough to remove but I suspect that walling-up the doorway is more than just a matter of mortaring blocks to fit in the opening. Are there any anchors or straps that would be needed also since I would be backfilling this area later,......very gently of course? Or any other structural elements I should know about?
BigArnold is offline   Reply With Quote
Old 12-29-2006, 05:52 PM   #2
Use rebar to secure it to the side walls.
redline is offline   Reply With Quote
More On This Topic
This is Ben Ingham with Expert Village talking about a walkout basement. As I was scouting the land, trying to find a place to where to build this. I was looking for land that sloped naturally this way and hopefully even had a drop off where the back of... Read More »
Hi, I'm Jeremy Blackwell. I'm here today to help you get started on your basement remodel project. Some of the common things you want to watch for in framing, is to make sure that all of your walls are plum, level and square. This keeps everything... Read More »
How To Brace A Doorway
How To Brace A Doorway by Expert Village
This is Ben Ingham with Expert Village talking about a walk out basement. It is just the way to get the border in place and get the block tap into the place in a way to clean out the joints so you have to have a little trowel when that is all over with... Read More »
What is an I-Joist?
What is an I-Joist? by Expert Village
This is Ben Ingham with Expert Village talking about a walk out basement. Once we get this wall corrected whatever problems and however we can go about getting it corrected and then the next step in the next procedure is to be sure it is reinforce and it... Read More »
This is Ben Ingham with Expert Village talking about a walk out basement. The crew came in and they help me get all this done and we have began by mixing up a huge batch of mordor and you put a bed of mordor down with a trowel, put the cement blocks down... Read More »
Travertine on cement in basement? Helpless Flooring 11 05-17-2007 12:58 AM
Removing cement walls in basement / replacing with I beam bbockstanz Building & Construction 9 11-19-2006 08:31 AM
Painting cement basement ?'s Dusty Painting 3 09-29-2006 07:27 PM
Uneven\Buldging Cement Basement Floor SSandecki Flooring 5 12-20-2005 07:06 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 03:07 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
