Need To Build Scaffold Planking - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-12-2009, 05:27 PM   #1
Rewards Points: 150
need to build scaffold planking
I need a platform at the top of my scaffold to do some ceiling work, one time use as a homeowner. I'm not buying anything premade or renting.
I have a sheet of 3/4 plywood but I wonder what size lumber I should use to act as joists beneath it. Needs to support 250 pounds total. 7.5' span.
johnnyboy is offline   Reply With Quote
Old 08-12-2009, 06:23 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 342
Ayuh,... Throw up a couple of 2x4s lain flat,+ top it with the Plywood,...
No need to get Fancy....
Bondo is online now   Reply With Quote
Old 08-12-2009, 06:54 PM   #3
I used (3) old 2x12's laid flat to support the plywood
These are actually 2" thick - not reg lumber
Bought sawhorse brackets to make my own sawhorses w/2x4's
Old 08-12-2009, 06:55 PM   #4
Rewards Points: 150
thanks.
Would like to build kitchen cabinets handyhall Carpentry 8 06-28-2009 12:15 PM
Build or buy a shed and costs? Piedmont Building & Construction 7 05-19-2009 08:13 PM
Sister floor joists or build support wall? Bcoleman6 Building & Construction 3 02-21-2008 02:06 PM
To Build or Not To Build scoby1978 General DIY Discussions 6 05-27-2007 05:39 PM
Cost to Build pallen Building & Construction 4 06-19-2006 12:43 AM
