And chain that sucker to the biggest post you can find. A generator running is like a predator call for a wolf around some parts of the country. Sorry to be negative.
Yea, I was thinking you should put expanded metal on the sides just to keep kids from touching it ( you did say it's on an ice cream stand right?)
I was thinking about something that looks like a radiator cover you'd find in a home, wood on top for rain protection, expanded metal on sides to give max ventilation without allowing curious hands to touch. You can buy 36"x36" sheets of expanded metal anywhere. Hardware cloth would be another affordable option
Yup, understood that part. Got it !!! That's what I'm talking about. There are all kinds of (steel and aluminum) truck boxes ready-made with the doors on the front of the box that could be opened while the unit was running. How would a wooden box protect it from weather if the exhaust were to burn it down first time they used it?
If the exhaust from his generator sitting in a ventilated box is hot enough to cause wood 6" away to combust I'd say he should stop pouring jet fuel into the gas tank and take it in for a tune-up
Yes our goal is to keep it running while out in the rain. Also to save money by building it ourselves.
The challenge is venting. Building a wood box and adding metal vents is an option. We are going to Home Depot and look at the types of vents you can purchase.
I think if we used a tool box it would need to be vented at the ends.
We also considered using 3 metal sheets with a pointed top leaving the ends open. It would need to extend well past the unit to keep the rain out. Hinging them together is a challenge and the cost is not cheap.
I think this is a problem for a lot of people and if we come up with a design that works we should post photos.
Just went through the same thing myself and found a simple solution If you google "simple generator cover" and click on videos you see my YouTube posting with photos. It involves an inexpensive cement mixing tray for $13 from Lowes and some mini bungy cords. I'm very happy with the results and hope others will find it usefull for operating a generator when it's raining outside. Best of luck
Use one of those cheap Poker tables from Wall-Mart. ($30)
Place table over Generator, cover table with a piece of tarp to protect the table top place a heavy rock or other heavy object on center of table so the wind wont take it away. And there, plenty of rain protection. Cheap and effective.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
