Old 11-07-2011, 11:14 AM   #1
Need a bit of help with my back patio construction plans
Hello all,
For this question I ask that you refer to the attachment with the colored coded wood beams.
I currently have a very old, and rickety aluminum patio roof, approximately 16ft flat sloped roof going off the masonry of my house. It's probably the ugliest thing on my house. I was thinking about tearing it down and replacing it with a 4x6 (blue in image), 4x4 (beige), and 2x6 (pink) wood frame construction, with tongue and groove 1x8 [not shown in attachment], asphalt felt and solar reflective paint on top of that [not shown in the attachment]. I currently have a concrete slab to work on (dark gray in image).
The roof has a 2 degree slope.
You'll notice on the back there isn't support, I figure a 4x4 anchored and lag bolted into the masonry would be ok? I could also put some vertical 4x4's against the walls to the slab supporting this as well if that should be done, but I don't currently have that planned (need advice there).
The scale of this is 8ft high at the beginning where it's attached to the house. The wide part is 27ft wide, it's 16ft length of roof.
My plan was to first make this a suitable patio area, then maybe, eventually close it in with insulation and drywall, with french doors (that's why the middle part has a bit more spacing between the 4x4). That part would be done at a later date. Right now, I just need a functional back patio.
My question among any other addressable issues here that I can't see is the roof. I cannot find 16ft 2x6 boards, and I don't want any weak points in the middle of the roof. Is there a certain kind of joist that would join these, or is that just not the right thing to do with a roof construction?
Thanks for any help you can provide! :-)
krwhite is offline   Reply With Quote
Old 11-07-2011, 11:32 AM   #2
concretemasonry's Avatar
Where in the world are you and what is the climate? These are very important factors. Your "flat" roof and wind uplift of a 16x27 roof can be considerable. - Make sure it is properly anchored to whatever slab you feel is adequate for the purpose.
Since you seem to be looking at converting the covered patio (in the future) into an enclosed room(different use and conditions), do yourself a favor and start out right since eventually it will be inspected by someone and you will have nothing but costly problems later. This could even come up when the house is eventually sold or other modifications are made.
When you say a "masonry" wall, what is the actual construction and method of connection?
Dick
concretemasonry is offline   Reply With Quote
Old 11-07-2011, 11:36 AM   #3
Thanks for the reply. This is in Tucson, Arizona. The home is constructed of brick. Right now I'm simply planning it out, and I do plan to get a building permit as well. I just want the plans to be pretty solid before I submit anything for approval.
Kyle
Old 11-07-2011, 11:42 AM   #4
Oh, and I was thinking about this sort of sleeve anchor. I mistakenly called it a lag screw above. A 6 inch one is pictured here.
Old 11-07-2011, 11:44 AM   #5
Kyle, am I understanding it correctly when you mention that you "can't find 16' boards"...? Do you mean 2x6x16...?
Runner6939 is offline   Reply With Quote
Old 11-07-2011, 11:46 AM   #6
Yes that's correct, it's 16ft 2x6's I cannot find. If I should joist some 2x6's perpendicular to those in the roof I would definitely do that. Again I just don't know. Thanks for the reply.
Kyle
Old 11-07-2011, 12:01 PM   #7
Well, in my experience, any reputable lumberyard will carry 2x6x16 lumber. It's what we consider a "premium" dimension in that we sell a LOT of them.
But in the absence of 16 footers, I've seen people "bypass" one joist past the other over a central beam. A couple of thing about this in my opinion:
First, I think you'd be better off. A 16' board is almost never meant to span 16'. And if I was going to spam that far, I'd use something beefier than a 2x6.
Second, if you do pass two single-run joists or rafters over a central beam, you want to use 10' or even 12' pieces, as I think most places like to see at least 10" of joist overlap.
You may already know all of this and if you do, I apologize. I just know the value of knocking ideas around & simply want to be helpful.
I'd be eager to learn which lumber yards have told you that they don't stock 2x6x16s. At least here on the East Coast, they're a dime a dozen.
(Not really, but you know what I mean...!)
Old 11-07-2011, 12:21 PM   #8
Thank you so much for the helpful advice. As for my inability to find the boards I think it probably has to do with my Home Depot & Lowes & [nothing else] search pattern. They do carry 12's, though. Thanks again.
Old 11-07-2011, 01:39 PM   #9
I forgot to ask, would you recommend 2x8 for this sort of span? Or, larger still?
Old 11-07-2011, 05:59 PM   #10
Residential Designer
AndyGump's Avatar
Send a message via Skype™ to AndyGump
One can DIY a lot of projects if they have a proper plan to build from and that my friend is what you need.
With a plan designed for your location you will be able to get a materials list, cut-sheet if needed permits and all kinds of other good things for your project.
Andy.
AndyGump is offline   Reply With Quote
Old 11-07-2011, 06:19 PM   #11
Good idea, Andy. Would you happen to know where I could find such info? I fail at google when looking for this kind of stuff. :-)
Kyle
Old 11-07-2011, 07:01 PM   #12
GuyJ's Avatar
Kyle,
I know this may be of limited use to you, and it isn't exactly what andy is talking about, but here is my town standard for patio covers . It has basic info about size of lumber and headers required for spans etc.. You may ask your city if they have a similar document.
One thing they make abundantly clear, is that if the patio cover is ever to be fully enclosed, the standard patio cover guidelines are worthless and the structure must be built to an entirely different standard.
Guy
GuyJ is offline   Reply With Quote
Old 11-08-2011, 01:27 AM   #13
AndyGump's Avatar
That is the kind of thing I do.
You can click anyone's icon to get to contact info if you wish.
Andy.
Tags
construction, patio, roof
settling foundation, many issues...including patio 1stimehomeowner Building & Construction 0 08-08-2011 10:11 AM
Need help making a 'back band' around window/door casing. RickDel Carpentry 3 07-15-2010 04:13 PM
need help evaluating patio work (photo) patio_newbie Landscaping & Lawn Care 6 07-11-2010 10:53 PM
New cememt patio stained by wet leaves Bhoward Landscaping & Lawn Care 7 12-03-2008 12:35 PM
Patio sliding door,Retro or new construction. Doug Crf Carpentry 3 09-11-2006 12:56 AM
