Need Basement Support Posts - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-16-2009, 09:45 PM   #1
Rewards Points: 150
need basement support posts
Where can I get new construction style, NONADJUSTABLE basment support posts? About how much are they? I know I can get the adjustable ones for about $45 and don't want to spend anymore than that. It'd be nice to get the solid ones though.
Carter Lumber, 84 Lumber?
I'll just cement the adjustment bolt if I use the adjustable ones, I believe this is standard practice?
Gotta go 6'9" (81")
johnnyboy is offline   Reply With Quote
Old 02-16-2009, 09:51 PM   #2
concretemasonry's Avatar
Rewards Points: 2,594
You need help!!!
Your are going to "cement" them in place to what?
What are they supporting? If they are for a new location you have have something under them there than a concrete floor of unknown thickness with probablt no soil supporting the slab for walking on, but not enough to support a new post.
Are you trying to replace some you do not like and are just shopping for some reason?
Dick
concretemasonry is online now   Reply With Quote
Old 02-17-2009, 12:25 PM   #3
Rewards Points: 162
If you install the adjustable head down (footing side), pouring concrete around it to infill the slab will "lock" the adjustable portion in place. When I built my house a few years ago, I followed this method.
I think your best bet is sticking with the adjustables. A steel fabricator would need to make a one piece non-adjustable column. In order to have the ability to adjust for level in the field, you would need to fab the columns a hair short and use shim plates under the base plate.
Some advice you receive on the internet can be worth exactly what you paid for it - be careful.
stubborn1 is offline   Reply With Quote
Old 02-17-2009, 09:21 PM   #4
Rewards Points: 150
The old basement slab is severly water damaged from standing water for a few years. The posts were rusted through. I pinned the beam with 4x4s, gave the old post one little whack and they cracked in half at the base. i dug out the old pads, poured new ones and will cement the adjustable posts' bolt below the new slab that's being poured next week.
stubborn1, yeah I guess you're right I'll just stick with the adjustable posts I already have. I only have a week, I didn't know they needed to be fabricated custom, I thought maybe someone would have precut lengths.
Oh well, thanks!
Q:Temp support to replace beam and posts on deck dougq Building & Construction 10 09-02-2008 04:24 PM
Replacing covered porch support posts yousah Remodeling 4 09-30-2007 12:15 PM
Support posts for 12' high deck hotchkiss Remodeling 3 09-05-2007 06:32 PM
Need help with basement support jaw522 Building & Construction 3 10-25-2006 08:55 AM
Temporary support for replacement of basement beam Mikedks Remodeling 8 09-14-2006 06:36 PM
