Old 01-06-2011, 03:54 PM   #1
Need assistance determining header specifications
I'm doing some remodelling and one of the projects I have is converting the unused "pocket" spaces on both sides of a bay window area into usable space for shelving.
The area itself is on the top floor of a three story rowhome in philadelphia that has a flat roof (so have to account for snow load). A link to a picture is posted at the end of this article so you can get a good idea of the space in question.
Each pocket area is roughly 5ft across. The existing framing is old school 2 3/4 x 3 3/4.
My current plan for each "pocket" area, is to remove the two middle studs (after building a temporary support), use 2x6's for the king and jack studs, and span the distance with a header made up of 2 2x12's sandwitching 1" thick plywood.
I'm not an engineer, so I have no idea of this set up would support the load correctly or if this would be overkill so I thought I'd post here to see if someone could provide some assistance.
Any help would be appreciated.
Thanks!
http://img820.imageshack.us/img820/3334/bayarea.jpg
rgb71 is offline   Reply With Quote
Old 01-06-2011, 06:38 PM   #2
I'm puzzled as to why you would cut into an exterior wall to install storage. Why not just build out the whole wall to whatever depth you need without messing with the insulation/framing?
mrgins is offline   Reply With Quote
Support for Header Shakemsam Building & Construction 4 12-04-2010 04:38 PM
Garage Header rwbil Building & Construction 11 09-16-2010 12:50 PM
Raise header of house wall plus add more header capslock Building & Construction 22 02-01-2010 10:13 PM
Help determining header size Griffith.N Building & Construction 15 10-03-2007 05:40 PM
Moving Header Supports Star Building & Construction 3 09-25-2005 01:50 AM
