Need Answer Before I Screw Something Up - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-28-2010, 11:56 AM   #1
need answer before I screw something up
I need some help with finishing off my shed's roof. Here's the problem; I have all the rafters (2x6's) attached to the ridge board but I left 5.25" on each end of the ridge so I could add a small overhang. I am planning on using 1x6's joined at the end of the ridge but don't know what to do about the small amount of exposure of the ridge. Can I just remove the inch or so of exposed ridge back to where the overhang will conceal it?
Thanks in advance to all who answer my dilema.
Larry
alke46 is offline   Reply With Quote
Old 04-28-2010, 04:35 PM   #2
DIY staff
Rewards Points: 7,174
If you could post a picture it would sure be a help.
Old 04-28-2010, 08:31 PM   #3
I will attempt to add the photo of the gable end I am talking about.
Old 04-28-2010, 08:35 PM   #4
i kinda like it sticking out. cut a nice pergola type shape into it
The older I get the better I was
The Following User Says Thank You to tpolk For This Useful Post:
Willie T (05-03-2010)
Old 04-28-2010, 08:36 PM   #5
Here's another pic of the gable end before the siding was attached.
Old 05-03-2010, 09:33 PM   #6
need help before I screw something up
I am moving this posting over from the construction section.
I need some help with finishing off my shed's roof. Here's the problem: I have all the rafters (2x6's) attached to the ridge board but I left 5.25" on each end of the ridge so I could add a small overhang. I am planning on using 1x6's joined at the end of the ridge but don't know what to do about the small amount of exposure of the ridge. Can I just remove the inch or so of exposed ridge back to where the overhang will conceal it?
Larry
Old 05-03-2010, 10:02 PM   #7
2 threads merged
I hope that is an illusion & those wires do not pass over the shed
Old 05-03-2010, 10:25 PM   #8
Registered User
Rewards Points: 5,516
I would have reduced the depth of the ridge board to the fly rafter's thickness which is one size smaller than the barge rafter. 2x8 ridge to 2x6 rafters minus the ridge board thickness. Then 5/4 x 8 barge rater face nailed over the ridge joints behind. Then 1x3 rake board on top of barge rafter. So the barge joints and the rake joints meet- hiding the ridge board/fly rafter joint. It's late and I'm tired, can you tell?
Phone lines, Dave! p.s. Nice job on matching the grooves!
Be safe, Gary
Gary in WA is online now   Reply With Quote
Old 05-03-2010, 10:31 PM   #9
Old School
Willie T's Avatar
A little sabre saw work, and you are in fine shape and aesthetically pleasing.
Willie T
Old 05-04-2010, 08:23 AM   #10
Originally Posted by Scuba_Dave View Post
2 threads merged
Yes, purely illusion. The wire are set back at least 6' from the shed.
Old 05-04-2010, 10:52 PM   #11
So what should I do here? Just cut the ridge board off flush with the end wall and then build out the 6" overhang?
Old 05-04-2010, 11:20 PM   #12
cocobolo's Avatar
Rewards Points: 5,956
Hi alke...I have a thread running here which might have some helpful photos for you. I just did a woodshed with a protruding ridge board. Still have not put the actual end fascia boards on, but you can see how the end of the roof was done.
It's the Gulf Island Building thread, and I think the appropriate posts are around number 635 and on, page 43. Hope it helps.
cocobolo is offline   Reply With Quote
Old 05-05-2010, 08:33 AM   #13
Thanks cocobola. I checked out your thread and was very impressed.
One question, are you going to put a fascia board on the front to cover the two end rafters where they are connected to the ridge?. Or is it just OK to leave it as is?
Thanks again,
alke46
Old 05-05-2010, 10:34 AM   #14
cocobolo's Avatar
Thanks again,
alke46
Yes I am, you're absolutely correct. Just need to find a couple of 1 x 6's to do that.
Old 05-05-2010, 10:37 PM   #15
cocobolo's Avatar
I have to send you a vote of thanks for kicking me in the beh...
End fascia on the woodshed was about the last thing on my mind. So today I found some cedar and put it up. Took a couple of pics and realised the end boards at the top - which I also did today - weren't stained.
Got that done just before 8 this evening and grabbed a quick pic.
It really does make a difference, even though it's only a woodshed and not the Taj Mahal.
need answer before I screw something up-end-woodshed-2.jpg   need answer before I screw something up-end-woodshed-3.jpg
Stuck Screw IceTreay General DIY Discussions 11 09-09-2010 01:56 PM
Swapping old 3ways with new (different screw color configuration on new switch) Michblaze02 Electrical 10 11-08-2009 02:17 PM
Can't get set screw in TP holder loose janralix Plumbing 4 08-12-2009 10:47 PM
gas line vs screw wobblybowl Plumbing 5 05-27-2009 10:49 PM
And they paid for this answer!! Scuba_Dave Electrical 29 02-16-2009 05:58 PM
