Need Advice On Windows - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-30-2009, 12:01 PM   #1
Rewards Points: 150
Question
Need advice on windows
My workshop is complete but without windows or ventilation. The walls were built on 24" centers. I found a vinyl HORIZONTAL sliding window for about $27. It's dimensions are 11 1/2" by 24". Can that type window be modified and/or used vertically? I really wanted to keep away from cutting into the wall studs, if possible.
shapeshifter is offline   Reply With Quote
Old 11-30-2009, 08:37 PM   #2
Rewards Points: 5,336
If it's a slider, then you need to install it horizontally.
Why would you install the windows after you built the structure? Retrofitting weatherstripping to seal the window will be unnecessarily burdensom.
Ron
Old 11-30-2009, 08:54 PM   #3
Rewards Points: 150
We built it from a kit that had no windows so they really aren't that big of a deal and neither is the weatherproofing. Just thought if I could find something smaller than 24" in width, we could cut the opening in the siding to install the window.
Old 11-30-2009, 10:09 PM   #4
I don't think you really understand what is required in weatherstripping an, "after thought", window installation. It goes hand in hand with the question of whether you could install a slider vertically. Both situations will result in water damage. You can't just cut open the side of a building and slap in a window.
Ron
Old 11-30-2009, 10:20 PM   #5
Rons right, not as easy to retrofit windows
Plus windows are built to shed water a certain way
A slider installed horizontal will fall out of the track
The sides turned horizontal were not made to shed the water
Installed incorrectly water will quickly rot out wood & mold will grow
Old 12-01-2009, 05:25 AM   #6
Mold!! Let's kill it!
Rewards Points: 2,012
In addition to the above, a slider doesn't have any balances to keep the sash in place. You'd have to lift the sash and prop it open. Look around for a narrow casement window. You'll be much further ahead.
Old 12-01-2009, 11:55 AM   #7
Rewards Points: 150
Thanks all for the advice. I will look for a different option, even if all I do is cut a piece of the siding out between the wall studs and put a piano hinge on it and a stick to hold it open when I'm in the shop
Condensation on Windows (PICS) - Advice Please livinginthepark General DIY Discussions 16 12-20-2010 07:35 AM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 12:18 PM
Windows bowing out at joining--any advice welcome. lemogirl Carpentry 3 08-10-2008 06:13 PM
Any advice on who to choose for windows? DaveLangdon Building & Construction 1 03-04-2008 07:17 AM
How do I install new windows? RickT Carpentry 17 10-12-2006 06:06 PM
