Need Advice Repairing Basement Walls
from both plugs in the 1 socket of the receptacle, i'd guess you have a sump pump w/separate pendant float switch - even a french drain ? not much you can do for the walls except remove all the paint & let the walls breathe,,, of course, the REAL solution depends on the size of your purse.
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders ! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
