Need Advice If Its Working Buying Or Making A Shed. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-16-2012, 05:18 PM   #1
Rewards Points: 152
Need advice if its working buying or making a shed.
Im thinking of making a shed this summer. A 5 feet by 8 feet shed. I looking at homedepot, their selling a 4 feet by 7 feet shed for $700.
When i start thinking about the material i need to build the shed; deck blocks, plywood, 2x4, shingles, vinyl siding, door. Is it cheaper to buy a plastic $700 shed, or build a shed?
humberguy is offline   Reply With Quote
Old 03-16-2012, 05:52 PM   #2
Rewards Points: 346
Those sheds are way too small, trust me, you will fill those up about three seconds after you open the door on the shed!
Build your own, there are all sorts of guides on doing it. Plus you will use better material than a lot of pre-made ones. The plastic ones are ok, they'll never rot or need paint, but I prefer wood.
Pardon any typos, my IPad has a mind of it's own for spelling corrections!
dougp23 is offline   Reply With Quote
Old 03-16-2012, 06:02 PM   #3
kwikfishron's Avatar
Rewards Points: 370
You’ve already done the math…
If all you want is to have a cheap roof over your lawn mower then buy the plastic.
If you want the satisfaction and pride in saying “I built that” then who cares if it cost a few extra bucks, you built it.
kwikfishron is online now   Reply With Quote
Old 03-16-2012, 07:06 PM   #4
MarginallyQualified
Rewards Points: 2,464
Get some stakes and masons twine.
Start laying out the space in your yard that works best.
See how much shed will fit there.
Whatever you end up with... in two years you'll wish it were bigger.
With that in mind think about where the garage should go when you place the shed.
Old 03-16-2012, 10:05 PM   #5
Rewards Points: 152
i have some dead space in my back yard that i dont use, that's why i want to build a shed to use the space.
I have one new questions now.
I have some scrap 2x4 i want to use to build the joist/base of shed. Would it be okay to use a 2x4 on a 8 foot span? I wont have the floor bowing in the middle? I dont want to buy 2x6.
Old 03-16-2012, 10:12 PM   #6
Rewards Points: 13,450
I would not use 2 X 4 for any floor joist.
If that floor fails the shed is trash.
Buy 2 X 6 pressure treated.
Old 03-17-2012, 07:11 AM   #7
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,114
joe is right about the floor joists. definitely use pressure treated, same with the floor sheathing
as for building or buying,, definitely build. i did the cost comparison for my shed 3 years ago. other than the wood siding it was about $300 cheaper for me to build my own shed than it was to buy the junk sold at the big box stores
i went with 2x4's 16" o.c as opposed to 24" o.c 2x3's on the kit sheds
woodworkbykirk is offline   Reply With Quote
Old 03-20-2012, 11:25 PM   #8
DIY Novice
I also ran into this dilemma, but am a bit hesitant about the framing for the roof as I have never done it. I think I have the general idea and I love a challenge, but I would need some pretty specific and detailed plans and instructions. I have looked at some (free) shed plans online and none of them have the detail I am looking for.
I would appreciate it if anyone has any suggestions for a very good set of plans (as of now I am thinking 8x10 or 8x12). I don't mind paying for a good set of plans, but need to know that they are what I am looking for before I buy. Free would obviously be better.
STK1200 is offline   Reply With Quote
Old 03-21-2012, 05:05 AM   #9
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,186
Unhappy
I built a16' by 24' shed, it is still to small
Coastal South Carolina
Need some advice on buying home termite & water damage. Mr Heshup General DIY Discussions 1 03-29-2009 03:06 PM
I need alot of advice on making corner shelving Funchal Carpentry 4 11-26-2008 10:25 PM
Urgent advice needed on sagging roof for home I'm buying jwoair23 Roofing/Siding 6 02-20-2007 11:17 AM
Buying house... Need advice! sweetsue777 General DIY Discussions 9 01-02-2007 04:11 AM
Need advice...rotten floor joists on house I'm buying strngelitlgrrl General DIY Discussions 5 08-01-2005 09:14 PM
