Need Advice -home Inspector Pointed A Problem - Metallic Pole Not Supporting Beam - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-27-2012, 09:34 AM   #1
Need advice -home inspector pointed a problem - metallic pole not supporting beam
Need advice -home inspector pointed a problem - metallic pole not supporting beam in the unfinished area of the basement.
The house is 10 years old - Pulte builder.
We are buying the house as 2nd owner, and home inspector pointed a structural problem in the unfinished area of the basement where the heater etc is present...
a iron pole not supporting the beam.
The pole is not aligned central to the beam, a metallic plate is fit under the beam and only 1/4th of the plate is resting on the pole. If it was a perfectly aligned the pole holes could be riveted to the beam holes. But this is not the case. Holes are just showing up.
Attached is the picture.
Please advice - whether it is serious and if so how it needs to be rectified. We are even doubting how it even passed through county inspection.
Thanks in advance
Need advice -home inspector pointed a problem - metallic pole not supporting beam-atta1.jpg
skRyan is offline   Reply With Quote
Old 02-27-2012, 09:44 AM   #2
picture of bottom needed and full pic of poll.
Hardway is offline   Reply With Quote
Old 02-27-2012, 09:45 AM   #3
Rewards Points: 13,712
What is the black material under that post bracket?
Old 02-27-2012, 10:26 AM   #4
Old School
Willie T's Avatar
Do you have the original plans? It may be no more than a "fail safe" measure someone stuck in there, and not even a part of the requirements of the plans.
If there's been no problem for ten years........... It's doubtful you'll ever have one.
If, on the other hand, the post was stuck in there to "fix" a problem......... then it bears further scrutiny.
Willie T
Old 02-27-2012, 10:45 AM   #5
retired union carpenter
Send a message via Yahoo to coupe
looks to me like lolly column needs welded to the beam. might need to remove some wood?
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Old 02-27-2012, 10:49 AM   #6
I am posting some more pictures..showing the entire pole
Posting some other pictures..
the black one seen is the actual beam.
Need advice -home inspector pointed a problem - metallic pole not supporting beam-atta2.jpg   Need advice -home inspector pointed a problem - metallic pole not supporting beam-att3.jpg   Need advice -home inspector pointed a problem - metallic pole not supporting beam-atta4.jpg
Old 02-27-2012, 11:09 AM   #7
Civil Engineer
Rewards Points: 4,770
Those pictures are too fuzzy to make out what is going on. You either need a better flash unit, or put the camera on a tripod, or get a different camera. I can't even tell from the pictures if the lally column is supporting a wooden beam or a steel beam. The top of the lally column looks like a home made bracket, never seen one quite like it before.
The Following 2 Users Say Thank You to Daniel Holzman For This Useful Post:
gregzoll (02-27-2012), Hardway (02-27-2012)
Old 02-27-2012, 11:15 AM   #8
clarification to Daniel Holzman's question.
The pole/column is supporting the dark iron beam.
The steel beam like structure is not a beam but the heating aluminium duct.
Old 02-27-2012, 11:20 AM   #9
Also Daniel Holzman - please look at the first picture which is more clear..atta1.jpg. The dark part above the pole is the beam. Thanks
Old 02-27-2012, 11:27 AM   #10
can one of these be put in place?
http://www.lowes.com/pd_97323-46417-...acks&facetInfo=
Old 02-27-2012, 11:53 AM   #11
Concrete & Masonry
Rewards Points: 568
Can't speak for everywhere, but that column top is just a simple "tab" top that was extremely common here for many years. No longer legal on new construction, but certainly compliant on a home ten years old. The maleable steel "tabs" are simply bent over the beam to hold it in place until it's loaded. As for this column, It seems extremely odd that the floor masons didn't straighten it out before pouring the floor, that's pretty fundamental. Not real easy to fix now though, w/o removing a little concrete floor.
jomama45 is offline   Reply With Quote
The Following 2 Users Say Thank You to jomama45 For This Useful Post:
gregzoll (02-27-2012), Willie T (02-27-2012)
Old 02-27-2012, 12:54 PM   #12
Civil Engineer
Jomama, interesting that you have seen such a tab top, I have never seen one. Are they supposed to be used by bending the tabs over the flange of the steel I-beam? That might make some sense as a mechanism to ensure positive engagement of the pole to the I-beam. What I see here, unless the photo deceives, is that the steel I beam is supported on the tops of the tabs, which looks totally wrong, and based on what you have seen, may not be the normal way to install the tab top.
Old 02-27-2012, 01:45 PM   #13
Concrete & Masonry
Rewards Points: 568
Yes, the tabs are intended to be bent over the upper side of the bottom flange of the beam. They are really just intended to hold the beam until it is loaded with weight. No doubt that bolting or welding is a better solution, but the tabs always served their purpose as well.
I think the ductwork in the picture is playing games with your eyes Dan. The tabs aren't fully bent over in the 180 degree position, likely due to the fact that the post is too far off-center. Here's a "catalog" of "Tiger Brand" posts, you'll need to download & look at page 9, but they show a diagram of what the plate looks like, as well as a few installed correctly:
http://www.tigerbrandjackpost.com/tbjp_catalog_2011.pdf
Old 02-27-2012, 02:01 PM   #14
Residential Designer
AndyGump's Avatar
Rewards Points: 684
Send a message via Skype™ to AndyGump
The pictures do pretty much suck and someone did a rather wasteful job of framing in the bath and that whole wall under the beam but I think I can make out that the pole is pretty much under the beam bottom flange.
It looks like the tabs for the pole on the back side do not extend past the bottom flange but the center web of the beam is directly on the pole it self. Whether or not is on there "enough" I can't be sure but from what I am able to see it would probably last another few decades or more.
Just guessing though.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Old 02-27-2012, 03:58 PM   #15
thanks.. but..
Actually, the pole is mis-alligned by few inches. So what the builder did is basicaly bent the plate edges one side, so that they go under beam. the weight is not transferring to the pole directly, pole head is covered under the beam by 20-40% it is not centered under the beam. The question is if this need to be fixed, what is the solution? Should we hire a structural engineer and a contractor to fix this issue or a handy-man can do the job?
Need advice on remodeling/renovating a prefab (mobile) home countrylifemom Remodeling 53 03-29-2015 08:15 PM
Need advice on footer pier problem paredown Building & Construction 3 03-20-2009 09:08 PM
New Non Electric Home...Need Advice Forest Breath Building & Construction 18 09-08-2008 09:07 PM
Need home buying/mortgage advice Badfish740 Off Topic 7 03-15-2007 05:28 PM
Urgent advice needed on sagging roof for home I'm buying jwoair23 Roofing/Siding 6 02-20-2007 11:17 AM
