Need Advice On Fixing An Old Shed - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-04-2011, 03:37 PM   #1
Need advice on fixing an old shed
I don't know where to start on my old shed. It's on a concrete slab. Some of the studs are rotting at the bottom as well as a lot of the bottom plate.
Also the roof has huge holes. I strapped a couple of tarps over it.
Where should I start?
How would I go about replacing the bottom plate?
How much do you think it would be to have someone else rehab this?
I'm attaching some pics
Need advice on fixing an old shed-resize-resize-resize-resize-old-shed-03.jpg   Need advice on fixing an old shed-resize-old-shed-01.jpg   Need advice on fixing an old shed-resize-old-shed-08.jpg   Need advice on fixing an old shed-resize-old-shed-07.jpg   Need advice on fixing an old shed-resize-old-shed-00.jpg
Plasbot is offline   Reply With Quote
Old 10-04-2011, 03:50 PM   #2
Framing Contractor
Rewards Points: 118
It is time for a do over. That shed is shot. Fixing it will cost more than new and will not be as good. The slab may still be ok, start with that.
sixeightten is offline   Reply With Quote
Old 10-04-2011, 06:19 PM   #3
I would agree with sixeightten.
Time to start over....By the time you buy all the material to fix that shed, you could just get a new one delivered. And if you factor in paying someone else to fix it......You could probably have an even bigger one delivered.
1910NE is offline   Reply With Quote
Old 10-04-2011, 08:49 PM   #4
Dang I was afraid of that. Well who sells sheds delivered?
Any advice on demolishing a shed?
Old 10-04-2011, 09:00 PM   #5
Msradell's Avatar
Rewards Points: 166
http://www.tuffshed.com/ is certainly a good place to start. They have. locations Nationwide so there may be one close to you. If not it will at least give you a good idea for price.
Msradell is offline   Reply With Quote
Old 10-05-2011, 06:50 AM   #6
DIY staff
Rewards Points: 7,174
Any carpenter worth his salt could build you a nice shed ----
Old 10-05-2011, 07:00 AM   #7
Mold!! Let's kill it!
Rewards Points: 2,012
Build the next one higher so it isn't setting in the dirt. It will last longer.
The Following User Says Thank You to Maintenance 6 For This Useful Post:
oh'mike (10-05-2011)
Old 10-05-2011, 10:45 AM   #8
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
You don't say where you are, but you might try Craigslist.
You might find someone interested in the barnwood to help you.
Old 10-05-2011, 04:23 PM   #9
Rewards Points: 212
A friend bought an Amish shed here in eastern Canada.
http://www.amishsheds.ca/
I'm sure there is a US counterpart somewhere near you.
Shed was 10x20, with galvanized roof, plywood floor, 3 large runners, door and window; and was delivered and set up on a clear stone. He is very happy and the shed looks great.
As mentioned, I'm sure someone would be interested in the barn boards.
orange is offline   Reply With Quote
want to build lean to shed, need opinions fenders Building & Construction 25 05-21-2012 09:39 PM
Looking for advice on rafter size for shed..... mlf Roofing/Siding 5 06-29-2011 08:00 AM
Correct way to wire a shed / workshop BOAH Electrical 10 01-05-2011 10:03 PM
unsafe wiring to shed? lawsklsux Electrical 7 11-14-2010 12:16 PM
Arrow shed on angle concrete foundation - how to fix? norcalty Building & Construction 4 06-18-2009 06:28 AM
